Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My TV shut off recently and just before it shut off I got an error warning that something was wrong with the airflow. Now it won't turn n and it keeps flashing yellow. Someone please help!
  • 460 Answers
First things first. is this set a dlp or a lcd if either it will have a projection lamp and when the filter for air intake gets clogged with dust and dirt it will cause the lamp to fail before its time is up.. have the lamp replaced by a tv service man..goodday.. p.s. expect to peel off about 300 skins..
Posted on Nov 15, 2009
Testimonial: "thanks for the advise! Not exactly what I wanted to hear but it is what it is! Thnak you!"
Why does my fully charged DC59 keep turning on and off
Hi there, it's Jack at Dyson.
DC59's motor will make a rapid pulsing noise to warn you if something is stopping airflow from passing through the machine. The motor will then shut off for protection.
This should be quick and easy to resolve by checking the motorised floor tool, wand and bin inlet for blockages. It's also a good idea to give the washable pre-filter a rinse in cold water if this hasn't been done recently - we recommend washing it at least once a month. Make sure the filter is allowed to dry completely for at least 24 hours before replacing it.
I'm confident this will resolve the issue. If you would like further assistance after giving these steps a try, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 10, 2015 | Dyson DC59 Motorhead Bagless Cordless...
Engine cut out while driving, won't start.
Lets start at the beginning.
If you have a V6 engine you have two cam sensors. And the problem could be the cam sensor(s) is not in sync with the crank sensor due to a problem with the sensor or the timing belt.
Code 340 is for bank one sensor one. You could have as many as 4 sensors depending on which engine you have.
The mass airflow meter code could keep the engine from starting.
The cruise control problem could be related to the cam-crank sensor issue or something else.
You should only have one crank sensor and it is usually near the crank pulley in the front of the engine.
Sep 29, 2012 | 2006 Dodge Stratus
My engine coolant temperature warning light came on, it started losing power and shut down. Now it won't start now. What is wrong with it?
if you dove it for a while wen the light came on you may have lost some engine coolant and now the engine may of over heated and sized up and now it wont work
Aug 03, 2012 | 2009 Chevrolet Cobalt
My 50in won't turn on
might have to change the bulb in the tv, should be in the back right corner should tell u something like a warning lable so u can find it,u will need a screw driver.
May 28, 2012 | LG 50PK250 50 HDTVReady Plasma TV
Car was working fine i parked outside my house then retired for the night i came out the next afternoon and it will not start
Hi
Sometimes the car won’t start because the wheel is turned the wrong way. Try turning the wheel and then trying it again. Check that the car is in park. If it was shut off in gear, it won’t start. Next, make sure the car isn’t out of gas.
Check whether the tires are stuck up against a curb or something. If so, turn the steering wheel firmly to the right or try to get out and physically move the car a bit and it should start. Do you have the clutch pedal down if it’s a standard? Or, if you have an antitheft device, check to see if that’s allright. Check your distributor cap for moisture. If you recently ran through a deep puddle, a damp or wet distributor cap will keep the car from starting. If there are cracks in it, replace it.
If you cant turn the car key then this is probably due to an antitheft gizmo that turns on when you shut off the car. Just wiggle the steering wheel a little and then try. If that doesn’t do it, turn the wheel as far to one side as you can and try again. This should get it going.
However if the battery’s good but the car still won’t turn over you may have a bad ignition switch. Try this test. Turn the key to ON (not start) and see in the warning lights are working. If they don’t and the battery connections are clean you have a bad ignition switch. If it's the ignition switch you probably will have to take it in to the garage.
Call for service if you’ve checked out all of the above things because the other possibilities will require a little more technical skill to discover.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
May 03, 2010 | Jaguar X-Type Cars & Trucks
I have a digimax i6 pmp camera, when i try to charge it,the light on the charger turns red, then starts flashing orange and the camera will not switch on at all..can you help me?
sounds like you have a bad battery ... the charger has detected something wrong and shuts down with the error warning .. replacing the battery will likely resolve the problem ..
Oct 12, 2009 | Samsung Digimax i6 PMP Digital Camera
Tv won't turn on
did you get any help yet with this problem?
Perhaps check out this forum.
http://www.highdefforum.com/showthread.php?t=25246
I think there might be a guy who can help you out with that problem.
Bunky
Mar 29, 2008 | Philips 30PW8420 TV
TV will not stay on
Sounds like you have a lamp error. Most likey there is something wrong with one of the lamps in the LCD itself, or you have a defective inverter.
Jan 21, 2008 | Sharp LC-15AV4U 15 in. LCD Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
