Question about Car Audio & Video
Vehicle cuts out under fast acceleration and blows puff of grey smoke
  • 11,896 Answers
White smoke is usually an indication of anti-freeze in the oil. Usually cause by leaky gasket. I recommend having a compression test done to make sure your head-gasket is not leaky and head is not cracked. If there is engine codes or check engine/service light is on, then it is a sensor or circuit that is faulty. Like 02 sensors or throttle position sensor.
I would first check head and gasket.
Posted on Nov 15, 2009
Why is my cub cadet xt1 blowing black smoke cleaned air filter made sure oil level is correct.still blows black smoke
Make sure that at full throttle the chock is not being used. Black smoke coming out of the exhaust of gasoline engine is a sign of a rich fuel mixture (too much fuel, not enough air). A brief puff of black smoke may be visible during hard acceleration when the fuel mixture goes momentarily rich, but under normal running conditions and idling the exhaust should be transparent. If black smoke is visible all the time and the inside of the muffler is coated with heavy black carbon deposits, it would tell you the engine has a rich fuel condition.
On engine, a rich fuel condition and black smoke can be caused by a stuck or maladjusted choke, a leaky metal or hollow plastic float inside the carburetor fuel bowl, or a fuel saturated foam plastic float, or an incorrectly adjusted float (set too low). A trestricted fuel filter may also contribute to a rich fuel mixture.
Jul 04, 2017 | Cub Cadet Garden
Hi my 2006 3.2 blows puffs of un-burnt diesel smoke intermittently after it has been driven in traffic
have the variable vanes in the turbo checked for correct operation
there is an actuator that is vacuum
electrical sensor controlled and the vanes may be sticking at slow engine operations as on traffic
the smoke color indicates incorrect air/fuel ratio and the turbo is a point to investigate
Sep 10, 2016 | 2006 Mitsubishi Pajero 2.5
Would a faulty egr valve on my 02 PT Cruiser 2.2crd cause excessive black smoke and injector knock under full throttle....thanks
black smoke is over fueling and although the turbo appears to spin ok the vale variation actuator may not be operating correctly
there are vanes in the exhaust turbine housing that are altered to increase the exhaust gas flow onto the turbine blades for quicker acceleration and these vanes are operated by a vacuum actuator and rod by a sensor
the vanes are subject to extreme heat and can rust stuck open or the hose gets hard and cracks
s not allowing the vanes to work
I would be concentrating in this area before the EGR valve
run the fault codes as well to get a better idea of the possible fault as some systems only put the light on for extreme conditions in engine and transmission
Aug 24, 2016 | Cars & Trucks
Blowing out black smoke an dont want to accelerate
Hi. I suggest you fix the misfire first. Most likely an ht lead or coil.
Apr 02, 2014 | 2008 Volkswagen Citi 1.8i
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
Blowing white smoke out of exhaust pipe
White smoke is usually a sign for a bad head gasket. How much white smoke is coming out? Also, are you losing coolant and can't find a drip under the engine?
Nov 22, 2013 | Cars & Trucks
GSXR1000 2001, After coming to stop and then intial acceleration puff of smoke from exhaust, has done this since new still only 6k miles on clock. Smoking did stop after it had 1st service at Beckleys and...
The valve guide seals are the problem. They were probably bad from the factory. The bike has 16 valves times $4 per seal = $64 in seals. The cylinder head gasket is $55 and a head cover gasket set is about $51. tombones49_277.gif
Sep 08, 2011 | Suzuki GSX-R 1000 Motorcycles
Thinking of buying an a4 tdi 1.9 diesel - seller says it smokes (grey) under heavy acceleration. Should I avoid it? Or is it livable wth (200k mileage)
grey smoke on acceleration is NORMAL for this engine,white or black avoid like the plague.....you could use an injector cleaner,redexe/wynns or similar.i use it every 25k,and (touch wood) no funny noises/smoke YET.expect oil consumption to be better than 500k per litre or a rebuild is needed.
Nov 15, 2010 | 1997 Audi A4
2005 chevy 6.6L turbo deisel losing power and blowing black smoke
pump may need recalibrating or a kit through it
or you may have a cracked turbo
Jul 20, 2009 | 2001 Chevrolet Silverado 2500HD
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
