Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frigidaire Refrigerator model FRS22ZRH not working. Freezer is working fine.
    Brigadier General:
  • 3,513 Answers
Most fridges nowadays have little heaters inside that defrost the ice buildup that is most likely blocking the cold air from going to the fridge from the freezer.
That may be the problem or it could be a sensor or timer problem that is connected to the heater.
All of the cooling in refrigerators is normally done in the freezer compartment. A fan circulates cold air from the freezer into the refrigerator compartment to cool it. Most likely this fan has quit working.
In short the most common reason for the failure is a problem with the self defrost feature of the refrigerator. This will cause ice to form on the evaporator coils that are located in the back of the freezer compartment. Defrost failure is often caused by a failed defrost timer or adaptive defrost control depending on the model of the refrigerator. If the defrost timer is not the problem the defrost heater or the defrost heater thermostat can also be the problem. These are located in the freezer compartment and can be accessed by removing the back panel inside the freezer compartment. These can be checked for opens with a volt/ohm meter. There is a fan in the freezer compartment that blows the cold air from the freezer to the refrigerator section to cool it. Make sure this fan is working.
Thanks for contacting Fixya.com
Posted on Nov 15, 2009
Why is my freezer working but not my frig in frigidaire upright with seperate doors
Check the rear is clean and clear. The condenser should be warm, not hot. If it cools down towards the end of the rungs and the last bit is cold. suspect short of gas.
Further check any fans etc and remove any excess ice, and make sure the door seals ok.
Aug 06, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Not freezing. coolant line gets cold then warm after compressor starts
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 17, 2011 | Frigidaire Freezer Refrigeration White...
I have a Frigidaire freezer chest. model number: mfc13m4fw3. It will click on for ten seconds and click off. I don't understand whats wrong. It wont stay on. Thank you
heatman101
Jun 29, 2011 | Frigidaire Freezers
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Freezers Logo
396 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
