Question about 2wire 2700HG-B Router (2700HGB)
I have a 2Wire modem and i need to Change my Mtu settings how will i do this?
    Novelist:
  • 111 Answers
A computer's MTU or maximum transmission unit is a measure of the amount of data that can be sent over a specific network protocol at one time. Because the various network protocols on your computer all have to communicate with one another the MTU of your system can have detrimental effects if improperly set. The MTU most often referenced when talking about PCs is the TCPIP MTU. This is the MTU value used for all internet communication on your computer.
  1. tep 1 Launch DrTCP and select the proper network adapter from the "Adapter Settings" pull down list box at the bottom of the program. The adapter you choose should be the one physically connected to your modem or router for internet accessI have a 2Wire modem and i need to Change my Mtu - mag-glass_10x10.gif via an ethernet cable. You can find proper hardware name of the adaptor by going to the windows control panel and clicking on "Network Places" to see which adaptor handles your internet connection.
  2. Step 2 Enter a numerical value between 1400 and 1500 in the text box labeled "MTU". This numerical value is transmitted to every remote server you request data from to be used as a common size of data to be sent with every packet of data sent to your computer. It is advised you start at 1500 and move down in increments of 10 until a satisfactory result is found. Usually MTU problems are not a result of your hardware or the remote server. The problem almost always is ISP hardware not supporting frames as large as you and the remote server have agreed upon sending. Lowering your MTU value in increments allows you to find the largest size possible without having packets dropped due to being too large.
  3. Step 3 Click "Save" and exit the program by clicking "Exit" or clicking the "X" button in the upper right corner of the windowsmag-glass_10x10.gif form.
  4. Step 4 Restart your computer for the changes to take effect and check to see if the changed MTU has increased system network performance. This process of trial and error may require several attempts to find a setting that is optimal depending on your specific network configuration. If you are unable to find an MTU setting that works a quick call to your ISP to ask what their recommended MTU setting should resolve things.
Posted on Nov 15, 2009
4 Suggested Answers
SOURCE: Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Posted on Sep 17, 2007
  • 192 Answers
SOURCE: MTU settings on Actiontec DSl Router
first you need to know th ip adress enter it in your internet browser. It may ask for a user name and password. You seting should then be displayed after that.
Posted on Jan 04, 2009
dexterlim29
  • 70 Answers
SOURCE: how do i change my 2wire routers mtu settings cant
you need to call your internet service provider because that is the firewall of the 2wire.
Posted on Jun 17, 2010
Isn't there an internet site where i can change my MTU settings on SURBboard sb5101, i need the settings to be at least 1364
It is not possible to change the MTU settings for cable modem... MTU settings are applicable only for ADSL connections like AtT or Verizon...
Dec 07, 2010 | Arris SURFboard® SB5101 Cable Modem
How do I change my MTU settings?
Hi
Please loginto the router management console
Then go into the interface mode
You can set the MTU as per your requirement inside the interface settings
By default the MTU is being set as 1500bytes on Ethernet type interfaces
Nov 01, 2010 | 2wire (1000-400108-001) Router
I cant access xbox live because my mtu is below 1364... how can i change this setting
it's not your MTU setting, you actually need to open some ports in your modem or router. Xbox can explain the port numbers, and www.portforward.com can help with the details.
Aug 02, 2009 | 2wire (1000-400108-001) Router
I have a AT&T router (2wire?) I need to change the MTU settings but when I go online I am haveing a hard time finding it. We have wireless internet and just got a wireless connector for our X-Box live...
Here is a good set of instructions, from a very reliable site. For 2wire specific info, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I need to know how to change my mtu setting
Xbox live is undergoing maintenance just wait it out,(tommorow.) ,
Jun 16, 2009 | 2wire HomePortal 1100 Router...
I have a xbox 360 that fails the mtu portion of the network connection. i have at&t dsl that is run through the phone jack to the router ( 2wire 2701hg-b) and from the router to the xbox. what do you...
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar: gateway.2wire.net/management
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Dec 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
Mtu
The modem (westell wirespeed)you have does not have is a old modem... that does have options to set the mtu settings. You need to change the modem. By the way why you need to set the MTU settings,.
Apr 07, 2007 | Westell Wirespeed LiteLine 6110 Modem
2wire 2700HG-B Router (2700HGB) Logo
711 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
