Oc failed enter setup to chwck oc settings - Computers & Internet
    Scholar:
  • 135 Answers
Could you please give us more details such as which computer (model number) and motherboard you're using? Do you know how to overclock and that's what you were doing? If so, you didn't overclock correctly and you need to change the settings back to the normal settings for your computer to boot up properly. You can change the settings in the BIOS, or "setup".
Posted on Jan 09, 2008
Suzuki forenza 2005 what is b1446 mean
short answer, Occupant controls failure. Passenger seat.
medium answer , air bags ,seat sensors and or seat belt systems failure.
Long answer.
no engine of the 5, are stated. nor country,
This is covered 100% in the book called FSM.
the factory service manual, on all cars. they have one
read it.? or at alldata.com and here
just $4 to read it.
https://suzukipitstopplus.com/
my best guess, is air bags (and ARE a danger to all mechanics that fail to read the FSM warnings, !!!)
the module is not communicating , due to power loss is the clue.
in case you dont know, error codes never tell you what part is bad
it at the least tells you what signal is dead, bad or a sensor not responding
what a tech,does, is do more test to ISOLATE the true cause.
others guess, and go broke fast $$$$$$
the Forenza is this Suzuki with Daewoo body and GM enigne,
are real pistol to work on,,,
rule 2, is the code is unique to suzuki, no other cars.
B1446 (i roll dice and guess)
2.0L engine, automatic.
out of FSM it states
but what does , OC mean,
its short, (not nice huh)
for
e Occupant Classification System (OCS)
Trouble Code: B1446 (2.0L L4 VIN - Auto)
OC Passenger Short to Power (Battery) or No Response
Trouble Code Conditions:
The OC sensor wiring is shorted to the battery wiring
Possible Causes:
  • Circuit
  • Sensor
OC rules before PLAYING around. a short excerpt.
If the vehicle is equipped with the Occupant Classification System (OCS), do not connect the battery negative cable before performing the OCS Verification Test using the scan tool and the appropriate diagnostic information. Personal injury or death may result if the system test is not performed properly.
Never replace both the Occupant Restraint Controller (ORC) and the Occupant Classification Module (OCM) at the same time. If both require replacement, replace one, then perform the Airbag System test before replacing the other.
Both the ORC and the OCM store Occupant Classification System (OCS) calibration data, which they transfer to one another when one of them is replaced. If both are replaced at the same time, an irreversible fault will be set in both modules and the OCS may malfunction and cause personal injury or death.
If equipped with OCS, the Seat Weight Sensor is a sensitive, calibrated unit and must be handled carefully. Do not drop or handle roughly. If dropped or damaged, replace with another sensor. Failure to do so may result in occupant injury or death.
If equipped with OCS, the front passenger seat must be handled carefully as well. When removing the seat, be careful when setting on floor not to drop. If dropped, the sensor may be inoperative, could result in occupant injury, or possibly death.
If equipped with OCS, when the passenger front seat is on the floor, no one should sit in the front passenger seat. This uneven force may damage the sensing ability of the seat weight sensors. If sat on and damaged, the sensor may be inoperative, could result in occupant injury, or possibly death.
Oct 20, 2014 | 2005 Suzuki Forenza
Hello! So everytime I start my PC my Asrock OC utility programs start "spamming" with errors like: "1.4750 is not a valid floating point of value". I am using a motherboard 890FX...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this task will schedule when computer restarts which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive do nothing while the chkdsk utility ani input may damage your computer then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them they could be faulty
hope this helps
Jun 07, 2011 | Asrock Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
OC fail warning comes.pc does not switch on at 1st time.next time it asks to do setting in setup. my config is hp dx2280mt, 945 mb, core2 d, win 07 os.
Hi, As I understand, you may have dead cmos battery or is not seated properly. I hope this this will you to solve the problem... Have a Happy New Year...
Dec 30, 2010 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Whenever i restart it says over clkocking failed.help
System was configured to run at a higher-than-rated speed. Just press the delete key when instructed to enter BIOS setup. It will probably reset to its default timing arrangements. Then press F10 to save the settings and exit the BIOS setup.
Apr 10, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Oc failed
in this case i assume the 'OC' is refering to the overclocking facility in your bios, so firstly press F2 or Del when your pc is booting up and, unless you have changed any settings to cause the fault, look in the cmos settings for 'Load Default Settings', save settings and exit for a reboot and see if the same message pops up. If so you may need to check the memory is seated correctly and any other peripheral connected to your motherboard, assuming it is a desktop pc. Isf still no change try resetting the bios by way of a terminal called CLRCMOS or CLR CLK or JBAT1, but you will have to refer to yourmotherboard manula or post the board details back here.
Aug 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
399 people viewed this question
David Payne
David Payne
