Question about Fuji FinePix Z10fd Digital Camera
My camera says protected card and it wont take the picture when i predd the button. what is wrong with it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 16, 2010
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
I deleted all my pictures and now when I take a picture
May be your memory card's button turned to write protect position. So please switch your button from locked position.
Apr 03, 2010 | Vivitar ViviCam 8025 Digital Camera
Card protected
Use a separate card reader to download your pics. Then, you can format the card in the camera to get it to work properly.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Some how when then memorie card is in it it wont allow me to take pictures or anything it like i accidentally pressed a button wrong or a combination of buttons my son may have done it PLEASE HELP!!
Please remove the memory card and try to take a picture...
If the camera works then the memory card "Write Protect" slider switch is set to "Lock" or the memory card is bad.
Please let us know what you find...
-Jim
Oct 17, 2009 | Cameras
Memory card is write protected
Hi..
Suddenly the card you have inserted is locked so that's why is says write protected. To unlocked the it get or remove your card from your camera. You can see in your memory card there is a small button her try to slide the button to unlocked. Insert your memory card back to your camera and try to take a picture it will take a picture.
Thanks for using fixya
Regards
PCmania
Sep 03, 2009 | Nikon COOLPIX L5 Digital Camera
Camera wont back up to memory card
Hi there.
Check to make sure the write protection is turned off on the memory card itself, the write protection tab is located on the left hand side of the card and is usually coloured white.
Good luck and thanks for using FixYa!!
May 15, 2009 | Olympus FE-20 Digital Camera
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
220 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
