Question about Palm Tungsten E2 Handheld
How do I do a hard re-set? - Palm Tungsten E2 Handheld
  • Palm Expert
  • 346 Answers
Here is a link that has a step by step guide to do the hard reset for your E2. Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/solutions/article/42094_en.html#tx
Posted on Nov 19, 2009
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
Jun 22, 2011 | Maxtor Hard Drive
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
How can I install my hard drive without the cd?
HI jamarrfinney
If you only want to install on your hard drive as backup, cd is not needed. just set the hard disk jumper to slave for IDE hard disk. If you are using SATA hard disk, no need to set jumpers, just insert the cable and then set the bios setup hard disk as a second hard drive (if necessary)
regards
Jan 11, 2011 | Computers & Internet
Is water hardness set at 19 softer or harder than water set at hardness level 25?
Water hardness set at 19 would be softer than 25...expressed as gpg or Grains Per Gallon
Nov 01, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Screen goes blank after a few minutes
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Jumper settings
the junper setting on a hard drive are:
Master - if this is the only hard drive in the computer, with the operating system on it.
Slave - If the hard drive is used with another hard drive in the computer.
The instructions are printed on the hard drive.
Apr 04, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Buffer of hard
Theres a couple of different buffer settings you can try. Your BIOS settings may let you get away with it.
Sata is a serial based hard drive. You may have some limitations to what you can set.
Check your mothboard or computer user guide for the bios settings concerning buffering for hard drives.
Aug 06, 2008 | Maxtor Hard Drive
Travelmate 2308 hard drive
Hello Goober....
Sure , You can change the settings here:
Click on Start (bottom Left corner of screen)
then...
Click On Control Panel
then...
Click on Power ..or "Power Options"(the icon for power settings)
then..
look there for what is Checked and Unchecked.... (in windows vista- you will have to first click on.. "change plan settings")
Once there.. You can change how your hard drive Runs... in Windows XP you just set the hard drive to .. NEVER... or you can simply set it to shut off after 30 minutes or an hour...
In windows Vista, to set the Hard Drive settings you will first need to click on...Change Advanced Hardware Settings...
Then Choose Hard Disk...then edit the settings there...
Hope it Helps... Happy Computing
http://www.wnycomputerpro.com
Jun 07, 2008 | Acer TravelMate 2300 Notebook
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Palm Tungsten E2 Handheld Logo
156 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
