Question about Acer Aspire 3935-6504 Notebook
How to take backup manager give step by step pls
What is backupManager
back manager is use to take a back up of ur imp files and even of ur complete os in case ur pc gets corrupt den u can recover ur pc folow to the give link here are step wise guide to do so
Solution 1 Windows 7 Backup Managing Backup Three Software Solutions...
Jul 31, 2014 | Microsoft Computers & Internet
Tip
How to jailbreak your ps3 (backup and play homebrew games)
How to jailbreak PS3(PlayStation 3)? chips available at www.ndsireland.webs.com
Follow the complete step by step guide posted below to jailbreak your PlayStation 3 to enable you to create backups of original discs.
Pre-requisites are as follows:
* Any (FAT or SLIM) PlayStation 3 Console running firmware 3.41 or above.
* PS Jailbreak USB Modchip.
* An external USB drive formatted to FAT32 with the "Backup Manager" file on it which you can download from here.
* Original disc of any PS3 game which you want to backup.
Step 1: Power off your console and make sure that there isn't any disc in the Blu-ray drive.
For the SLIM Model: Remove the power chord before plugging in the USB.
For the FAT model: Turn off the power switch found at the backside of the console.
Step 2: Now insert the USB based PS Jailbreak Modchip to any USB port of your choice on the console. Once the USB is in place, Power ON the console and immediately press the "Eject" button. There should now be two LEDs turned-on on the USB as the console is loading.
If the LED light on the USB turns green, you are good to go as the PS Jailbreak has been successfully loaded.
If the LED turns red, then it means that the PS Jailbreak Modchip didn't load successfully. This usually happens when the Power and Eject button sequence wasn't performed properly. Start from Step 1 again if you end up having the red light.
Step 3: Once the console has finished booting up with the PS Jailbreak Modchip, plug-in the external USB storage device which has the "Backup Manager" setup to the console's USB port.
Step 4: Now navigate to the "Game Menu" and select the option "Install Package Files" and then select "manager.pkg" file. This will basically install the "Backup Manager" application that you download earlier to your hard drive.
Step 5: When the "manager.pkg" file is done loading, scroll all the way down in the "Game Menu" and there you should see a new application called "Backup Manager", run it.
Step 6: Now we're in the Backup Manager app. Insert the game in the console's optical drive which you want to backup. Press "O" and you will be asked where to make the backup, on the internal HDD or the external storage source connected via USB. This process is further elaborated by the following screenshots.
Step 7: In order to play a game via the backup you just made, insert any original game disc into your console (To emulate the loading process), run "Backup Manager" in the "Game Menu". Press "X" to play the selected backup game.
Step 8: Now you will be taken back to the main menu. In the "Game Menu" you will see the game which you have backed up. Now you can select the game, and run it without having the disc in the console's drive.
Oh and you must make sure that the PS Jailbreak USB Modchip is connected to your console at all the times when you are playing the games via backups.
Disclaimer: This guide is for educational purposes only. I'm not responsible for any loss of important data or malfunctioning of your Game Console.
on Oct 06, 2010 | Sony Playstation 3 (PS3) Console
My nokia 7210 supernova cant play the musicplayer.and when i keep trying.it will hang.and and whitescreen and it will off.and then it will open again.help pls
hi! nothing to worry! i'll give a simple steps to solve! first of all u need to install nokia pc suite in ur desktop or laptop! then u need datacable and bluetooth enabled lap/pc (dongle is enough).connect ur phone with pc(desktop)/laptop. then backup all ur contacts messages and files by browsing phone browser in that nokia pc suit file manager. then u wont worry dissconnect ur phone! move to phone "tools" option and select manager. then uninstall all ur unwanted softwares. and move to "settings" option in the menu. then move to original settings option in that option then enter code if it asked. (default code is 12345) the it ask u whether to restore all phone setting's to original state! hit ok! ur phone restart ! that's it ur problem solved ! clean ur phone data that already u backup with antivirus in both pc and phone antivirus! hav a nice day! rate me if u like!
Jul 17, 2011 | Cell Phones
I get an "Error 513"
Here is some good info:
heck below steps for OS upgrade -
Step #1
Before starting make sure you have BlackBerry Desktop Software installed on the computer.
Step#2
Make sure that you have installed updated device OS is installed in your PC. Check this link to get update device software from carrier OS download site:
http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore apps in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer
  2. Open BlackBerry Desktop Manager
  3. Open Backup and Restore
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
Step#4
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager
  2. Open the Application Loader it will prompt if there is any new/updated OS is available
  3. Click Next to start the installation process
  4. Type your BlackBerry smartphone password, if prompted, and click OK
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. When the process has completed, the message The loading operation was successful will appear.
  7. Click Close to return to BlackBerry Desktop Manager.
http://supportforums.blackberry.com/t5/BlackBerry-Curve/quot-JVM-Error-513-Reset-quot/td-p/590718#M70865
Post again if you need further assistance and good luck!!
Just to give you another option, try this if you would like:
Ok, you may lose your data, but try this first to see if you can load the opertaing system without losing your data.
See the link below, for the download and simple installation instructions.
First locate your carrier and the OS file you wish to use.
Do a backup of your device first, using Desktop Manager > Backup. Close Desktop Manager upon completion.
1. Download the OS file to the PC then install it to the PC by running (double clicking) the file you downloaded.
2. Go to c:\program files\common files\research in motion\apploader and delete the file named "vendor.xml."
3. Plug in BB and double click on "Loader.exe." It's located in the same place as the above vendor.xml file.
Thanks!!
Jun 28, 2011 | RIM BlackBerry Bold 9000 Smartphone
I put the battery in and the it loads goes and have a quarter left and then is goes white and says jvm error 545 and reset please help me now
Step #1
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Step#3
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
Step#4
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager
May 03, 2011 | RIM BlackBerry Storm 9530 Smartphone
I have blackberry 8110 showing jum error 547
Hi, you need the desktop manager, and you need to download the current software version for that device, its going to wipe everything out on the device, but you will get the device to work. after you download the the software, you need to run it on your PC, and then use the APP loader on the desktop manager to install it to the device.
Step #1 Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2 Make sure that you have installed updated device software installed in your PC.
Step#3 Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps: Connect the BlackBerry device to the computer running BlackBerry Desktop Manager. Open BlackBerry Desktop Manager. Double-click Backup and Restore. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases. Choose a location to save the backup file, then click Save.
Step#4 To perform a clean install of the BlackBerry Device Software, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click the Application Loader icon. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Click the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then click the check box beside Erase all currently installed applications. Click Next. Click the check box next to Do not automatically backup the application data during the loading process. Clear the box next to Backup and restore applications installed wirelessly. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Feb 23, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
I want to restore my Acer AOA 150 ( mini netbook) to factory default setting. The problem is that Acer Recovery Management is not working. when i click on it No action it takes plz tell me the...
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer mini notebook to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer mini notebook to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer mini notebook is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Dec 25, 2010 | Acer Aspire One AOA150-1504 Netbook
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
Jvm error 547
Here is the procedure to resolve:
Step #1
Step#2
Step#3
Step#4
Click Next.
Jan 18, 2010 | RIM BlackBerry Pearl 8100
HTC Audio manager is not working. Giving error
Dear take a backup of your mobile memory data (memory card data backup is not required) and then go to Start>Settings>System (Tab)>Clear Storage, This will reset your mobile and that would all Audio Manager error.
Jan 08, 2009 | HTC Touch P3450 Smartphone
Acer Aspire 3935-6504 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
