Question about RIM BlackBerry Curve 8310 Smartphone
Hi, My keypad does not work anymore, When I press any button on the keypad nothing happens, how can I fix this?
  • 395 Answers
You can try fixing this problem fixing this problem first by pulling your battery out and placing it back in. After this you can try using your keypad once more.
Kind Regards
Posted on Nov 15, 2009
My start button isn't working....I can press the "popcorn" button and it will automatically turn itself on and cook whatever I have placed in the microwave, but nothing happens when I press the "start"...
If it will start automatically without using the 'start' button, the 'start' button must be bad. If the door sensing switch was bad, it wouldn't start at all. It needs a new keypad. The most common cause of a keypad failure is from spraying a cleaner on it instead of using a just barely damp cloth to clean it. The liquid can run down the front of the laminated keypad and get into the bottom and seep up into the lamination....
Nov 03, 2013 | Jenn-Air JMV9169BAS Convection Microwave...
MODEL 139.53975SRT1 1/2 Hp opener will not work with any remotes, I tried to reprogram remotes; pressed learn button, the light next to it came on, pressed button on remote, nothing happened. I cleared...
The correct way to program a remote is to hold the button down on the remote and then press and immediately release the learn button. If this doesn't work your logic board is bad.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot get keyless entry to work. Bought new keyp...
That keypad should work with your opener. I suspect the keypad is bad if you have other remotes that work. If not it could be the logic board.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
The power button doesn't work to power on the phone. I press and hold it and nothing happens. I'm guessing it could be a hinge problem. The times when it works the keypad doesn't even light up when open.
I have same problem, as if the Power button is squished since it likes to shut off randomly. When I squeeze the sides of the phone to 'raise' the button of the contact point, it works again, as well as lights the keypad.
Store said hardware issue and would fix it but money better spent towards a new phone...
Jan 02, 2010 | LG VX-8700 Cellular Phone
Buttons don't work
Hello there
Normally this is a sign of the controle pad malfunctioning wich is very common you will have to replace the controle pad
If you have your warranty still use it
If not the pad can be replaced it will cost about 30 dollars for the part and if a repairman does the job ait will cost about 80 dollars for him to do the job
ok
Best regards richard
Nov 27, 2009 | Microwave Ovens
My se p990i flip keypad malfunction
It has a flex/ribbon inside the flip keypad,you must replace it or the whole flip k-pad.
Jul 22, 2009 | Sony Cell Phones
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Problem ok keypad
Hi ankushritu,
Your problem is because of your misplacement towards.. the keypad holders you check for that and if it doesn't happen after your try.. you go on towards a mobile phone service store for a service.... this happens regularly..... al de bes...
Oct 20, 2008 | Nokia 6233 Cellular Phone
Keypad
check tour keybord conector and cable.It will be work fine.
Apr 30, 2008 | Motorola Mobility E398 Cellular Phone
Front cover buttons not working
has this area been wet at any stage?
Nov 01, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry Curve 8310 Smartphone Logo
146 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
