Question about Bosch Ovens
HBN7052GB main oven trips house circuit breaker
A few months ago I had to replace the element in the main oven of our HBN7052GB. Recently the oven caused the main circuit breaker in our consumer unit to trip, plunging the whole house into darkness. I've subsequently discovered that the oven will work quite happily when set to 150º but if I set it to 200º it causes the CB to trip when the temperature approaches 200º. Can anyone suggest which component is most likely to be failing?
  • btemple642 Nov 15, 2009
    Hi. Thanks for your reply. No it's not a genuine Bosch replacement part but it's worked fine for about five months. I have tried removing it and connecting it directly to the mains without it tripping the breaker and also, the fan is running at full speed.
    The original element was replaced because of a similar circuit breaker problem. Disconnecting the element stopped the breaker tripping so I assumed it was the element that was at fault.
  • Andy Thomas
    Andy Thomas May 11, 2010
    Hi . From experience I would say the element is faulty. Was the replacement element a genuine make one or a aftermarket type? Before the problem accured did it "appear" to cook at the right temperature? Also check that the fan iside the oven is rotating quickly
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
kibonghe
  • 25 Answers
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Posted on Feb 04, 2009
  • 44 Answers
SOURCE: Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Posted on Mar 19, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
protek480
  • 1714 Answers
SOURCE: Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Posted on Sep 01, 2009
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Where is the fuse for a 9 year old Kelvinator undercounter oven situated?
There is none. Look in the circuit breaker box on the outside of the house for the one marked oven. It will be 2 breakers side by side with a metal part connecting both levers together. Move both handles back and forth a couple of times. That may restore power to the heating element. If one breaker trips it leaves 120 volts to work the light and the clock, but the element is 240 volts. It may have shorted with age. You may need to replace the elements if the breakers keep tripping after you reset it at the panel.
Jul 28, 2016 | Ovens
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Have replaced burnt-out element in main oven. Red light comes on when control turned, but no fan or heat.
an open circuit indicates infinity which means no ohms and what the element should read is a closed circuit. open is bad and needs replacement as for the no fan check for loose wire or power issue also might want to check for a blown fuse
May 06, 2015 | Ovens
Grill on my tecnik tkc8525 tripping out my house electric. Any ideas ?
Probably heating element goes to ground when heating up. Suggest changing element.
Nov 10, 2014 | Tecnik TKC8525 Double Oven
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 | Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 13, 2011 | Smeg Ovens
Ovens Logo
115 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
