Question about Motorola Mobility RAZR V3
Possessed Razr Ok, I bought this phone (razr v3) on-line last week. I charged it immediately before use. It doesn't hold a charge very well so I tried a different charger (same model as the charger sent with the phone.) BUT NOW out of the blue this thing is setting its own volume. From across the room I hear bleep bleep bleepbleep... I look at the phone and it is as if some unseen hand is pushing the volume button over and over.. Then the bottons don't work, not even the on/off botton. I took the battery out and reinstalled it, now it doesn't bleep it just flashes what it is doing to the volume..At this moment it set itself to vibrate.. I KID YOU NOT!!! I know this sounds weird but its true. If you have any suggestions I would appreciate it. Otherwise I think I will just send it back.. Thanks
  • crazyrazr Jan 09, 2008
    By the way, the phone is new and I have not dropped it or spilled water on it. All the plastic stuff is even still in place...
  • crazyrazr Jan 10, 2008
    Today the phone has behaved and not repeated yesterdays haunting... Should I still do the relash?
    Brigadier General:
  • 7,752 Answers
No my friend that does not sound weird the phone software is corrupted....you just need to have the phone firmware reflash to the original version.....that will correct the issues....or if you wish you can return the phone and have them replaced it.
Posted on Jan 09, 2008
My razr v3 died yesterday. tried all night charging, still dead. no juice to turn on. bought 2 years ago, worth new battery?
Well... I would say no.. Not worth battery.. I had the same thing happen to me where my phone wouldn't charge and we bought a new battery for $50.00 and then we find out my phone is shot.. so I would strongly recommend getting a new phone..
Oct 09, 2009 | Motorola Mobility RAZR V3
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
RAZR V3 - New battery w/full charge drains in 1hr of standby
take out a battery and check if there is any red paper dots on the back of the phone. If you do have a dot that is at least partially red, that means that your phone got wet and it can not be fixed.
Nov 15, 2008 | Motorola Mobility RAZR V3
Razor battrey
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Jul 08, 2008 | Motorola Mobility RAZR V3
RAZR V3 WITH PLANATRONICS BLUETOOTH
try a master reset of the phone or delete all BT devices in your list....hopefully this corrects the issue
May 26, 2008 | Motorola Mobility RAZR V3
Razr V3, charging the battery
take it to motorola service center
May 25, 2008 | Motorola Mobility RAZR V3
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3xx not powered on
you need to charge a phone over night for the battery to fully charge and have a memory
try plugging in as charging and turn phone on by holding the red button down for a few seconds on the right hand side
Oct 11, 2007 | Motorola Mobility RAZR V3
USB Cable and charging problems
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Dec 08, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
108 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
