Question about Garmin zumo 550 GPS Receiver
Only says enter pin what I can doe
Only says enter pin what I can do it
Enter four zeros
Posted on Nov 25, 2009
How do you unlock my PUK cold cool pad
  1. Contact Customer Care to request your PUK code.
  2. Tap the Phone icon to open the dialer.
  3. Note: If your phone is not yet PUK locked, touch Emergency Call on the screen where you enter the PIN code.
  4. Enter **05*[PUK]*[New PIN]*[New PIN]#
    Note: If this does not work, enter only the PUK code, then the new PIN if prompted.
  5. When the phone displays 'Unblocking PIN: Registration was successful' tap OK.
Feb 02, 2016 | Cell Phones
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
Nov 24, 2012 | Grundig Televison & Video
PUK Blocked? What does that mean?
The PUK & PIN codes are Security Codes that are on the SIM card. PIN( Personal Identification Number ) PUK ( Pin Unlock Key). when the PIN code in entred wrong the SIM automatically Blocks the PIN. to unlock the PIN you need to Enter the PUK. but if you enter the PUK wrong the Entire SIM is Locked.
The PIN Code & the PUK codes are Only Known by your Network Provider. you have to get in touch with them to get the codes. how ever if you have PUK blocked you will have to get a replacement SIM
May 09, 2010 | LG Xenon GR500 Cell Phone
How do i unlock my samsung SGH-D980?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/sg/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=archivedmodels&model_nm=SGH-D980&mType=&dType=D&vType=R&prd_ia_cd=01010600&disp_nm=SGH-D980
“Phone Lock” from page 5 in your quick manual:
• The automatic locking function has been enabled.
You must enter the phone’s password before you can use the phone.
Enter PUK from page 5 in your quick manual:
• The PIN code was entered incorrectly three times in succession and the phone is now blocked. Enter the PUK supplied by your service provider.
Enter PIN from page 5 of your quick manual:
• You are using your phone for the first time.
You must enter the Personal Identification Number (PIN) supplied with the SIM card.
• The PIN Check feature is enabled. Every time the phone is switched on, the PIN has to be entered. To disable this feature, use the PIN check menu.
From page a in your manual: Same link as above quick manual.
Try this to solve the problem:
Please insert SIM card. Ensure that a SIM card is installed
correctly.
Phone lock. When the phone lock feature is enabled, you must enter the password you set for the phone.
Enter PIN. When using the phone for the first time or when the PIN requirement is enabled, you must enter the PIN supplied with a SIM card. You can disable this feature by using the PIN lock menu.
Enter PUK. One of your SIM cards is blocked, usually as a result of entering your PIN incorrectly several times. You must enter the PUK supplied by your service provider. If all else fails you can call Samsung at 1-800-726-7864.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SGH-D980 Cell Phone
Forgot my pin no.
Resetting the unit does NOT reset the PIN. Even a Master Reset will not reset the PIN. You have three options for unlocking a PIN locked Garmin:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
Apr 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
HOLD ON!
You may enter wrong PIN three (3) times only. After that your PIN will be blocked! To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented) After entering correct PUK, you will be asked for NEW PIN.
So, when it says "PIN blocked. Enter PUK code", you must enter the PUK. If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
Dec 25, 2008 | Cell Phones
Pin2 block
ok if it blocked you was it the sim that was blocked does it say enter puk code?
if it does ring your carrier and give them your details and they will give you the puk code and enter it then the phone will say make a new pin and renter new pin
Jun 28, 2008 | Cell Phones
Unblock
puk is for the sim card buy new sim card...security code is for mobile
Feb 09, 2008 | Nokia 5300 Grey Cellular Phone
Garmin zumo 550 GPS Receiver Logo
125 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
