Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I can not close my liftmaster garage door - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
Most probably your door sensors are not pointed at one another. They each have a small light that will be lit if they are aligned properly. If that doesn't take care of the problem you may have a sensor that failed.
Posted on Nov 15, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door closes but opens inmediatelly and partially,only 1 foot and a half
With the garage door up pull the release cord to disingage the garage door it self in the up position. You can skip the disengaging step, But,It saves ware and tear on the motor.
Then using a step stool you will find limit adjusting plastic slots/screws on the side of the opener.
The left screw is for garage door down.
I would turn the left screw clockwise 1/2 turn or less. then activate the remote opener. noting which way the latching mechanism moved. and so on.
It may take a few adjustments with this proceedure to get it perfectly closed. Then activate the remote to re-engage the garage door it self.
Also, LiftMaster has a web site that you can check out.
Jul 23, 2011 | liftmaster Garage Door Limit Switch...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
219 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
