Question about Polk Audio PSW10 Subwoofer
Solution to Vibration
I have a polk audio powered sub woofer on wooden plank. The range is set in between 120-180 hz. My neighbour complains every time that there walls vibrate when i watch movie even in midafternoon on a sunday..How do I help myself to isolate these vibrations and help the neighbours too?
    Problem Solver:
  • 5 Answers
You might try to turn it down and maybe move it somewhere else in the room i have the same problem its just my neighbors are in another house across the yard i just have way to much power god forbid some one family or what ever be in my house.
Posted on Mar 13, 2010
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
My receiver has one pre-out will a psw10 work
yes but a sub woofer out is better. You may have to crank up the sub response. If it has a level on the sub with a crossover set the cross over to around 120hz. And set the bass on your receiver as you feel appropriet.
Nov 09, 2013 | Polk Audio PSW10 Subwoofer
What r the parametric specs for the ma audio hk15x2
Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
Feb 16, 2011 | MA Audio HK15X2 Car Subwoofer
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Whats the rateing on the polk 10 inch sub woofer
Hello dread2477,
The Polk Audio db1040 is a single voice coil 4ohm subwoofer. The db1040DVC is dual voice coil with 4ohm coils which can be wired in parallel for a 2ohm load, or in series for an 8ohm load. They are practically the same sub. The RMS power range is 50-270 watts, with a maximum peak power of 540 watts.
The full specifications including recommended enclosures and physical dimensions can be found here.
Hope this helps.
Aug 03, 2009 | Polk Audio Car Audio & Video
Polk Audio PSW10 Subwoofer Logo
173 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
