Question about Maytag PYE2300AY Electric Dryer
The first hose blew off the back of the dryer after replacing the hose it now sounds makes a loud racket and smells hot. What can this be
  • 126 Answers
Make sure that you don't use the plastic type of vent hose. This is meant for non heat, like a bathroom fan. If you have metallic venting, go outside and see if the dryer air is able to come outside with some force. If not there is a blockage in the venting somewhere. If you went for a while without realizing the first one blew off, you could have built up a lot of lint inside the dryer. You will have to take it apart and vacuum it out. If lint gets onto the element when it heats up you will smell it burn.
Posted on Nov 15, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
My dryers plug shorted out and tripped the breaker. I replaced the plug and turned it all back on and it worked.....then seconds later a loud poof sound from the dryer and now nothing is working. Please...
when a plug shorts out like your has,it creates a surge of current for a moment,it could have ruined or weakened the element,motor,thermal fuse or even pierced a wire electrically and when you re-powered the circuit it blew out this weakened component,the loud poof you stated sounds like the element burned through and blew out creating an arc and the poof sound
May 05, 2012 | Kenmore Elite HE4 Electric Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Dryer runs hot and a little louder
sounds like the thermostat needs to be replaced
Jun 15, 2009 | Amana ALE643RB Electric Dryer
My dryer gets really hot, but the clothes take a long time to dry and it is really humid inside the dryer. Also, there is a weird smell almost like a burning smell.
It sounds like the dryer isn't getting enough airflow, which might mean a clog.
Make sure you clean the lint filter every time. Also, make sure the vent hose isn't kinked or clogged (if you can, remove the vent hose and clean it out.) Also check between where the vent hose connects to a wall or pipe. There could be a lint clog anywhere between the dryer and where the air leaves the house.
Dec 02, 2008 | Dryers
Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag PYE2300AY Electric Dryer Logo
60 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
