Question about Keurig B50 Coffee Maker
Funnel does not lock in place - Keurig B50 Coffee Maker
    Champion:
  • 213 Answers
It may be worn out. If you need a new one you can find it here.
http://iwantsweetdeals.com/Keurig-Breville-Replacement-K-cup-Holder-Assembly-P1208231.aspx
Posted on Jun 14, 2010
How do I put transmission fluid in my 2011 Hyundai elantra
Find the transmission dipstick and buy a funnel, place the funnel in the tube and fill to the manufacturer specs
Aug 06, 2014 | 2011 Hyundai Elantra
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
I inherited two different blowers. i can't see how the only bag i have can fit on my weed eater barracuda 2595 and can't find any diagrams on line. once i open the spring door the bag doesn't really fit...
OK this may seem difficult but its really not. The spring door there are only 2 things to do with it open. Either you put in the round circular attachment and then close the door or you attach the bigger of the 2 "funnels."
The big funnel is used to **** up the leaves and it will NOT work WITH that circular attachment attached. The Barracuda will NOT blow leaves without the circular attachment.
If you want to blow leaves, open the swing door, put in the circular piece with a twist to keep it in place, close the door and attach the smaller "funnel" to the smaller opening on the front side of the blower.
If you want to **** up leaves open that swing door, take out the circular piece HOLDING OPEN the swing door and in that same place attach the larger "funnel". Where the smaller funnel goes is where you attach the bag! There should be a small opening in the bag with a velcro strap. Put that over the opening of the blower, attach in place with the velcro and your ready to **** the leaves! When putting on the bag, make sure the bag shoulder strap is facing the top of the blower, not the swing door.
Hope that helps. Now on to find the solution to my problem!
dlandlrd
Oct 30, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have a Bunn model VPR, I can fill it up with water, plug it in, no water. turn it on, no water. it gets hot. I opened it up, there is no restriction. What coulf cause this?
This is a pour over unit.
You fill the tank with water, it heats the water in the tank.
When the water in the tank is at brewing temp, the lite should go out.
To brew coffee with this system, you put a filter in the brew funnel, put coffee in the filter. Place the brew funnel in the slide tabs to hold in place. put an empty decanter on the warming plate under the brew funnel. Then take one decanter of fresh water and pour it in the top of the brewer where it says "WATER ONLY" the coffee will begin brewing immediatly.
Oct 26, 2009 | Bunn VPR-Black (33200.0002) Coffee Maker
Would like to install locking gas cap cover on 08 Wrangler. How does original come off? Don't want to force anything until I'm sure. Thanks.
Does your Wrangler have a cap that is attached with a tether (chain, or plastic cord to prevent loss of cap?) If so, just cut it to remove the cap. Stant makes a locking cap for an 08 Wrangler, available online or in stores.
Jul 11, 2009 | 2008 Jeep Wrangler
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Lg refrigerator water dispenser would not shut off
so two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Apr 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Non stop ice
the clear funnel is either broken or just popped out of place.
if you can get a flashlight and look at the funnel you will see two clips on both sides of the funnel that secures it to the lever just push firmly and it should go back into place. if you dont have any luck you can order the funnel and replace it fairly easily.
one thing that may help you repair this unit is remmoving the front cover of the dispenser.
on the bottom of the cover is 2 slots for a flat tip screw driver. just insert the driver and leverage outward and the snaps will release. (it takes quite a bit of force). be sure to unplug the refrig to prevent getting shocked. when you reinstall the cover you will have to hit the lower portion firmly with the palm or side of your hand to lock the cover back in place.
Dec 17, 2007 | Whirlpool GS6NBEXR Side by Side...
Keurig B50 Coffee Maker Logo
146 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
