Question about Microsoft Xbox 360 Elite Console
Games are being scraped when loading - Microsoft Xbox 360 Elite Console
  • loonyliam May 11, 2010
    check for any marks or anything on the tray
My x-box tryes to load my games, then goes to open tray sometimes it says redeem code, on a few occasions it has loaded my game in after all the problems before. Please help!
try a lens cleaning disc.it work for me for a while.if it dont work ,go on ebay and order a t8 screwdriver.when u have it look on you tube to see how to take off the casing on your xbox..remove all the screws.once done remove the otherside of the outer covering.then remove the metal shell of the top,which will expose the inside of your console. disconnect the 2 leads that go into your drive.ps try not to scrape the mother board.remove drive carefully,take out the 4 crews and carefully pull the casing apart.next get a hair dryer.(cool setting) and blast all the dust from everywhere.get a cotton bud and use the weight of it to gently wipe any remaining dust from your lens.then blow on it..put casing on drive again and reconnect leads.and place back in original place.plug console in ,turn on and insert game.test it,and it should boot the game up straight away.
if its ok .put the rest of console back toghether properly and your good to go. it took me 20 mins to do then it worked first time every time.trust me.it works.
Dec 19, 2012 | Microsoft Xbox 360 Console
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
After a game when it goes to franchise home page it freezes
could be your disk, there are cd shops and eletronic stores that can scrape a little bit of the plastic casing on the bottom of the cd making it playable but this can only be done once/twice, any more than that it may scratch some data off
Jun 30, 2009 | Microsoft Xbox 360 Console
PS2 slim will not read disc and making a scraping noise
Hi, the optical lens assembly is damaged. you will need to replace this assembly asap. the assembly has become unstable and the alignment is compromised.
Jun 05, 2009 | Sony PlayStation 2 Slimline Console
Scraping noise when drum turns over
possible something has gotten through the tub "holes" inbetween the drum and the tub
May 16, 2009 | Kenmore Washing Machines
Scraping noise from dryer
probably one or both the rollers in back of drum are no good these rollers are near the motor
Apr 18, 2009 | Maytag Dryers
Slimline PS2 makes weird noises
u gota change ur ps2 lens...this problem always occures when the lens gets old!
ur only choice is to change the lens! and you can't do it alone! have to take it to experts
Sep 16, 2008 | Sony PlayStation 2 Slimline Console
Load scraping(not squeaking) and rubbing noise when applying the brake. It can be felt in the floorboard.
Any rubbing or scraping noise should be reported to a qualified local mechanic for immedeate brake inspection. YOUR LIFE IS ON THE LINE HERE.
Jul 28, 2008 | 1988 Buick Regal
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
My psp doesnt read UMDs properly
I started to have this problem with the games that I play all the time. What I noticed is that the game starts to sink into the case. I got mine to play by first, pushing on the reading side of the disk. Later, I had to take the plastic front piece off that has the UMD label. You have to be careful because the actual UMD disk can come out after that. You also have to be careful because you don't want to crack the whit case that holds the UMD. I hope that this helps.
Apr 06, 2007 | Sony PlayStation Portable (PSP) Console
Microsoft Xbox 360 Elite Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
