Question about KitchenAid Kitchen Ranges
I am getting an error code F6E0 lost on my Kitchenaid DF Range
I am getting an error code F6E0 lost communications on my range.....the problem seemed to start at one point where the tip of the meat thermometer probe broke off in the socket within the oven. The message to input the meat probe temperature would often come on without the probe actually in place. Today I pulled the stove out and got to the socket and was able to remove it and get the small tip out of the socket that broken off a few months ago. I hoped that would fix the overall problem, however it did not and the F6E0 lost communications message came up. The model number is KDS907SSS01
  • randallheinr Nov 15, 2009
    Thanks....I think I might be getting deeper into the electronics of this than I might be capable of handling. This oven is just over two years old and the owners manual indicates that control panel is still covered in years 2-5. Would this be under that warranty? If yes, I will avoid taking off panels and probing around in areas I best not mess with. Do you think this problem could be driven by the original broken off tip of the meat probe in the socket? Or is it unrelated? I have removed the small tip of the original broken probe from the socket in the oven wall. Please advise. Also, how do I find a qualified service tech in my area that would honor the warranty if it is still in place? Thanks
    Randall
    Thanks for your help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F6 E0 means lost communication with the appliance manager . House Power Supply Most “F6-E0” complaints have been due to loose connections at the house power supply. Verify electrical connections are good at the house power supply Unit Terminal Block "F6 E0” code can also result when L1 is not connected. Verify correct voltage between L1 to L2 at the unit terminal block. Appliance Manager Board "P1" Connector.
The MW Appliance Manager (AM) board is powered on L1 and will not 'talk' to the display board if L1 doesn't make it to the board. Verify the correct voltage is present between P1-1 (L1) and P1-2 (N) of the MW Appliance Manager, Fuses & Thermostats. An open microwave monitor fuse, Cavity thermostat or an open 20A magnetron fuse (next to the AM) will produce an F6E0 error. Check that all fuses and thermostats are operating correctly Appliance Manager Board. The MW Appliance Manager Board can crack at the corners where the screws attach it to the support. Look for cracks at the corners where the mounting screws secure the board. If cracks are found, the board will need to be replaced. Caution should be taken when replacing MW Appliance Manager Board. The board can flex when connectors are plugged and unplugged and cause cracks.
Before doing any replacement or performing any repairs I’ll suggest you to reset the unit. Unplug it for 1-2 hours or reset the breaker. Also check for the bad ground wires that are not fully grounded on the unit.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 15, 2009
  • Rylee Smith
    Rylee Smith Nov 15, 2009
    Hi
    If its still under warranty then you can get it replaced/repaired as the part is covered under warranty. Moreover, if there is any other issue with the range they'll also fix it to ensure control panel's proper working.
    I'll suggest you to contact Kitchen Aid ASAP to get the issue fixed. Do mention that you have consulted a tech and it is an issue with the control board. Tell them about the error as well.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Nov 16, 2009
    Hi
    Thanks
    Rylee
    President:
  • 1,015 Answers
Sounds like it could be a loose connection to the control panel. You could try unpluggung the power to the range for 10 minutes and then plug it back in and see if it clears. I think it might be unrelated to the probe issue. If it is still under warranty then you may not want to mess with it or you could void the warranty. You will need to contact the manufacturer for warranty service on the range. They will probably ask you for the serial number,model number, and date of purchase. Then they will send someone to make repairs.
Posted on Nov 16, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Oven does not work is reads F6E0 error code lost communition what's wrong?
I assume it's a KitchenAid that you have. Here you can find a previous thread about this code:
http://www.fixya.com/support/t1176150-f6e0
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Ovens
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
Lost communications error code F6E0
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Sep 10, 2010 | KitchenAid KESS908SPS Electric Kitchen...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
KITCHENAID KGRS807 ERROR MSG F6E0
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Feb 22, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid gas range KGSA906PSS
Google kitchenaid error codes...
I have had three ranges and at least five circuit boards so far... they are garbage, if under warranty, call and complain LOUD.
Jan 17, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Ranges Logo
242 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
