Question about Husqvarna Viking 1
Machine speens but not the needle...
Just started steeching the jeans.... I was about to finish so started doing reverse steeching and suddenly the machine runs but the needle is not moving making the jeans stuck with machine.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like the motor belt has come off the machine. It needs to be serviced by an authorized husqvarna viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
My top tension is off. It was factory set for 5. I checked needle size, bobbin tension, thread, and for any build up of fuzz. I have a White Jeans machine. If I turn the top tension dial to 7, the bot
Sandra,
If the needle jams when sewing over thick items, it may be you have a dull needle? Not all machines can hem blue jean material without a hand to help the flywheel around, through the doubled over seams.
Additionally, when sewing the basic two pieces into one piece, start with the presser foot ON the fabric about a half inch sewing in reverse first, backing up to the fabrics edge and then proceeding forward through your fabric.
Fabrics too heavy or too light, are the common issues with home and commercial sewing machines.Knowing your machine and how to operate it; will get you through these "issues" when sewing.
Cheers, Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Jan 01, 2015 | White Sewing Sewing Machines
Needle size for singer 3014
Your machine takes standard sewing machine needles, available from quite a few manufacturers like Organ, Schmetz and Singer. I have even seen them for sale in drugstores! Most people use #11, #12, or #14 needles--the higher the number, the larger the needle, and the thicker the material. In addition, Sharps are used for all woven fabrics like cotton and wool; ball point needles are used for things like t-shirts and other knit fabrics. Home sewing machine needles range from #8 to about #18. For instance, you would probably use a #14 or #16 needle for Jeans, although for those, there are also specialty Jeans needles you can also use.
Jun 11, 2014 | Singer Sewing Machines
Sewing machine needle hitting shuttle
The timing has moved, re time the machine.
Jan 26, 2018 | Sewing Machines
How to fix your needle assembly on your sewing machine
Sounds a bit serious, jeans fabric is dense and thick. Many machines struggle especially sewing hem over side seam with 6+ layers. You need jeans needle size 90, 100 or 110. Maybe take in for a service as the needle assembly could be out if time too 10_23_2013_1_43_35_pm.png
Aug 01, 2013 | Sewing Machines
I have a 2011 Juki DDL-8300N. Has always worked fine but while sewing on denim it suddenly seized up and stopped sewing. The needle is in the lowest postion through the jeans. I am unable to turn the
Your needle probably bent and got jammed. clip threads top and bottom of the fabric and remove... then get in the bobbin area and look for issues.
Sep 30, 2012 | Juki DDL-8300
My Elna 7200 doesnt feed properly especially if I start out with a bulky seam. It also has problems crossing seams. Any ideas?
You could try using a seam jumper when crossing bulk, this is a little plastic device that you put in front and behind the pressure foot to keep it level as it goes over the bulk. This then means the machine can keep feeding the fabric evenly. WIthout it, the feed dogs arent getting enough pressure, the machine slows and can't feed the seam, your needle may deflect and strike the foot, and broken needle may be the result.
Here is a link to one called a Jean a Ma Jig, http://sewing.about.com/gi/dynamic/offsite.htm?site=http://www.clotilde.com/store/
Also, try bashing the seam you are wanting to sew across first with a hammer and always trim the seam allowances inside the seam if you can. If sewing denim, use a denim needle with blue coating, it helps it pass between the densely woven fibres in this fabric.
However, it may be that your machine just hasn't got the strength to stitch through more than 6 layers, many wont. Especially if you use buttonhole twist thread to get the read to wear jeans seam finish. I often resort to using my old SInger 20U industrial straight stitch when altering jeans.
Nov 05, 2011 | Elna 7200 Computerized Sewing Machine
Tension adjustments- bobbin metal or plastic-needle size- for sewing on jean cloth
Most machines can sew on jeans fabric, but you may need to go slowly or even hand-turn the needle when crossing thick seams to keep from bending or breaking your needle.
Bobbin: It won't matter if you use plastic or metal bobbins.
Needle: You should use a heavier needle - you can purchase 'jeans' needles, or use the heaviest sharp or universal needle you have.
Tension: For tension adjustment, you can follow the guidelines in your sewing machine manual but you'll also need to adjust the tension based on sewing on scraps of the fabric. If you are sewing light-weight denim, the settings are pretty much the default/normal settings. As you increase the weight/thickness of the fabric and seams to cross, you'll need to loosen your pressure foot tension. If you use decorative 'jeans' thread or topstitching thread, you'll need to loosen your needle tension.
*Always test on scrap fabric to make sure the stitches are forming properly. It is best to make small adjustments to your tension settings, then test, then adjust and test, until it is right. If you sew that weight of fabric often, make note of your tension settings inside your machine manual to save you some time the next time you sew.
I hope this helps.
Apr 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
I have model 3101FA. The needle jams and does not extend into the bobbin area, somethimes I can reverse, by hand, and it clears it. It seems to not make a difference whether I have the bobbin in or not....
Perhaps you have a bent needle? Change the needle, make sure the size of the needle matches the fabric you are working with. Use a size 90 or 100 for Jeans, and a 70 for lighter weight fabrics.
Change your needle frequently! A professional changes after each project, you could get away with 2 or 3 projects. And when you start sewing make sure the threads are under the feet, to the back of machine, don;t start at the raw edge, or you have a bird nest real fast. This is because your machine as an oscillating rotary system. (going back and forth and not in circles) Those systems are more sensitive to jamming. Sorry I could not help you earlier.
Dec 17, 2010 | Necchi 3101 Mechanical Sewing Machine
I cut off jeans and turned them up to hem. Following all the directions in the manual, I began to sew, but the thread broke after only a few stitches. My thread is all-purpose thread. I tried tips in...
I turned up my husband's jeans using a size 100 needle. You can get easy thread needles that have a small gap in one side that you slide the thread through. There is a good way to turn up jeans and keep the original hem without having to cut them. Have a look at this site http://www.daciaray.com/?p=38
Aug 25, 2010 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
50 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
