Question about GE Profile DPSR473EW Dryer
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Posted on Nov 29, 2009
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 15, 2009
Ge dryer Model # DPSR473EWOWW
once you get the dryer apart & remove the drum its very siimple
a 10 minute job if that
Apr 21, 2014 | GE Profile DPSR473EW Dryer
Ge dryer Model # DPSR473EWOWW coil proper installation
once you get the dryer apart & remove the drum its very simple
a 10 minute job if that & if your not sure get a service tech so you dont do more damage
The ge profile dryer #dpsr473ew is malfunctioning. it makes a very loud squeaking noise when it is on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 31, 2011 | GE Profile DPSR473EW Dryer
My ge dryer is hanging clothes around the drum and leaving them black. mostly wash cloths at a corner. it has a squeak like a cricket.
Hello darrellandru, the problem is most likely going to be the drum slides. On the top drum bering, there are four plastic strips, the drum sits on these strips and those strips are what the drum rides on. You may also have problems with the drum gasgket (the felt that is on the bottom plastic drum bering).
Sep 23, 2010 | GE Profile DPSR473EW Dryer
GE Profile Dryer #DPSR473EW making loud noise while clothes are drying
take the back off and physically look at what"s going on back there. oh, and unplug it first...
Dec 08, 2009 | GE Profile DPSR473EW Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile dpsq495et0ww has a severe squeak to it. we checked out if it was the belt. and the belt looks good. when we take off the front door it doesn't squeak when we turn it on but if i manually turn it...
The problem could probably be with the drum bearings or the drum support rollers. The following link direct you to the internal diagrams of this dryer model with the part selection in case of any damaged parts. Hope that helps you out.
Dryer internal diagrams
Also will look out for manual and will post in few hours. Please do rate my solution if accepted and also post comments regarding any doubts with the solution provided.Good luck with the machine.
Sunny
Apr 08, 2009 | GE Profile DPSR473EW Dryer
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Dryers Logo
1,129 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
