Question about Measuring Tools & Sensors
Is there a book available for the Swanson Speed square I lost my book but have the speed square
  • 288 Answers
Go to swanson.com
Posted on Dec 23, 2009
My car will not drive forward suzuki sidekick nd 1995
hello. Yolanda , welcome.
so is reverse dead too>?
is the car a STICK shift or auto>??
if auto shift transmission, is it 3speed or 4,
the 4 speed look like this.
see the 2 on the shifter (that is 4 speed)
http://www.fixkick.com/tranny/slush/4sp-selections.jpg
if its a 4speed we need to scan it,
if 3 speed, the 3speed box is bad. or levels low,
ever check levels by the book, or lost the book?
http://www.fixkick.com/tranny/checks/AT-DIP.pdf
Mar 14, 2015 | 1995 Suzuki Sidekick
Why is a speed square 7 inches ?
Hi Joe,
Yes it is 7" X 7". I offer two videos to enjoy its usefulness. Extreme How To Original Swanson Speed Square
Here is a stair layout 12" X 12" with attachments Swanson Big 12 Speed Square . I prefer stair gauges and a layout square. Either method s good.
Here is the link for a variety of topics and input on the uses of the squares for your library.
Fare. Well. Swanson Big 12 Speed Square for Stringers
Dec 31, 2014 | Office Equipment & Supplies
2005 gmc sierra heater fan quit working. I lost the fifth speed months ago and a couple of days ago lost the other four, the first day the fan would come on sometimes while driving then quit after a while...
1-4 speed are the blower motor resister . It controls all 1-4 speeds, also it's under the passanger side dash around fan, the 5th speed runs off a fuse the is located in the fuse box. It's one of those square fuses , not the relays but fuses. The resister will run $15 and fuse $5 . Good luck. I have replace these before
Jan 03, 2011 | 2003 GMC Sierra 1500
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
I have lost my manual for the hp laser jet i need step by step instructions on how to change the speed dial numbers
Here is the Technical Reference Manual for your Printer. As you can see below, your add numers to the Fax Phone Book, within the HP ToolBoxFX.
GOOD LUCK
Fax Phone Book
Figure 2-42 Fax Phone Book screen
Use the Fax Phone Book screen to add and remove individuals or groups on your speed-dial list, import
phone books from a variety of sources, and update and maintain your contact list.
Feb 18, 2010 | HP LaserJet 3050 All-In-One Printer
Need to know how to figure a rafter cut
Assuming you already know the angle you require, take the edge with the level on it(if you have that model) or the side that hangs over and hook it on the edge of the board. If you look at the top, on the 90 degree end, it says "pivot", and that is where you will spin the square around. You read on the 45 degree end that was hooked to the board for you angle. If you are trying to cut a rafter at a specific pitch such as a 6/12 you will spin the square around until the 6 on the Common scale lines up with the edge of the board. The Hip/Val scale is for cutting hips and valleys for the roof structure.
If you have any other questions, feel free to contact me here
Bob
Sep 11, 2009 | Swanson Speedlite Level Square
KNOWING RISE OVER RUN HOW DO I USE THE SQUARE TO MAKE MY ANGLE?
Run is alway 12".
Example 4" (rise)/12" (run)
Measure 4" on one leg of the square and 12" on the other leg. Connect the points and there your angle.
Jun 29, 2009 | Swanson 119 High Visibility Speed Square
Speed dial
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows:
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
Measuring Tools & Sensors Logo
192 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
