Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
I fill the hot water tank and it and it pours out of the tank onto the floor less than a year old used to work fine
The tank is cracked under the plastic cover. I am on my second machine. The first one was cracked when I brought it home. I have maybe used the second one 20 timed and now it is leaking all over the floor. If you turn the tank over and look at where the pastic cover snaps on to the tank you will see some indentations to lock the cover in place. Both of mine machines tanks cracked there. It is kind of a poor design. It is a week spot in the tank. Hope this help.
Posted on Nov 24, 2009
Don-I too have the same issue. I tore mine apart today and still don't know what the issue is...I have a Hoover Dual V...I'll let you know once I find the solution. Like you, mine machine is just at a year old.
Posted on Nov 21, 2009
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
My steam glide russell hobs iron pours out water when used I have burnt my self a few time. It also leave the garment very wet.
Many persons put too much water in a steam iron.
Make sure that you do not fill it all the way to the brim.
Try using less water in the tank.
This may also solve your wetness problem.
Aug 29, 2011 | Vacuums
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Bissell 8930 Pro-Heat wont dispense water/cleaner onto floor, but attachment works fine.
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
Jul 21, 2008 | Bissell Vacuums
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Water leaks
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Oct 13, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
133 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
