Question about Motorola Mobility RAZR V3c Cellular Phone
My phone stopped charging
I recently had my wall charger for my motorola RAZR broke and my friend gave my a USB cable...it worked and then i wanted to charge my phone on my others laptop and it didnt work so i just left it there plugged in while i played a game
after that my mom got my a diff battery from my dads old phone it wasnt he same kind of battery and i put it in and it didnt work
so i put my regular battery in and my phone didnt turn on or anything the USB cable didnt work anymore and whenever i open my phone my screen is blank button the lights around my buttons blink
i dont know what to do
  • 319 Answers
Hello
Please follow instructions here. I just tried it with my Razr, and it worked!
Let me know if this works, if not we will look for another problem.
Thanks
Brian
Posted on Jan 09, 2008
6ya staff
SOURCE:
I left my Motorola Razr 3 on charge last night as usual. This am it had switched off & will not switch on again. I have attached it to my computer via USB charger & the green light is showing on the front...
Computer will not charge your phone if the computer is off, may stop charging during standby or sleep mode. If failure to charge over night was on wall charger its a problem with charger/cable. OR your phones battery is junk.
Aug 11, 2013 | Motorola Mobility RAZR V3
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Home Charger Quit Working
Hi!
Its not due to charging it via usb. Your charger is not giving full amount of charge and thats why its charging with the usb but not with the charger. And, if that is not the case then somehow an internal ic inside your phone is blown and needs a repair.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Mar 01, 2009 | Motorola Mobility RAZR V3
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
V3 battery
you need to get a proper battery
Dec 30, 2007 | Motorola Mobility RAZR V3
Motorola RAZR won't charge
that happens mostly with third party chargers..you may want to explore the option of charging your phone using the PC and a USB cable...you may be required to download a software or driver for it ..along with eh motorola phone tool
Apr 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
