Question about Acer TravelMate 2300 Notebook
I have acer travalmate 2420 model when i am trying to plugging the adapter then the adapter led is switching off and laptop is not going to start. it does not having the battery backup please suggest me what can be the problems
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
  • 110 Answers
SOURCE: My Acer Aspire 5920 is not booting up. When the
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Posted on Sep 08, 2009
Testimonial: "Thanks for the reply! This just confirmed what I had been suspecting looking at other sources on the web. "
  • 2567 Answers
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
sriramoju
  • 171 Answers
SOURCE: I have an Acer Aspire
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Posted on Oct 24, 2010
  • 184 Answers
SOURCE: My Acer aspire 4935 is
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Posted on Feb 10, 2011
I have an acer 5920 with a problem , When you plug the jack in the power adapter led gets off. It seems like the laptop is shortcircuited somewhere. I know this is a common problem with some acer models ,...
Have you tried to plug it in without the battery?
If not and the laptop start then your battery might be the issue. Try another cheap one from ebay.
If yes then open the laptop and check if the power plug socket is on the mother board or separate. If separate you might found the module on ebay. It could be worth a shot. If attached then The motherboard is.....You know.
Aug 29, 2013 | Acer Aspire 5920-6727 Notebook
My acer travalmate 6293 works fine when using its battery but when I start to use it while on charging, it hangs. I dunno what's going on. Please help me....
Your power from the charger flows through the batteries for your computer. Move the connector around slightly and see what happens. If it continues, there may be a problem with the connector or plug.
Aug 22, 2011 | Acer TravelMate 6293-6727 (LX.TQP0Z.C54)...
Travemate2420
Go to Tigerdirect.com they have the best adapters and if you call they will get the best match for you and they will be cheper than most
Jan 23, 2011 | Acer TravelMate 2420 Laptop AC Power...
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Laptop not working on battery, i have changed the battery
There are several simple indicator to determine the source of the problem. There are 4 major components involved, the laptop circuitry, contact terminal, AC adapter and battery. Every laptop has a LED light indicating if it is in the charging mode (without powering up the laptop). Start out with your laptop shutdown. Pull out the battery, then plug in the AC Adapter. See any LED light go on? Try again, the same procedure now with the battery plug in first, then plug in the AC adapter. See any additional LED lights go on? If there is no different, than the laptop can not detect your battery. If the AC adapter can power up your laptop, you can eliminate the battery (assumed brand new battery) & AC adapter. This only leaves you with the laptop circuitry & contact terminal. If your laptop can charge up your old battery or any battery, then it might be still the battery & contact. So, you try these procedure to reduce down to the "problem" component.
Oct 13, 2009 | Acer Aspire 5315 Notebook
My ACER 5920 will not boot up when the charger is plugged in th
Dear Sir,
By analysing your problem it seems to be your adapter dead.So first check your adapter,so your laptop battery may not have backup to turn on the laptop.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
Hi, I can not download Bluetooth driver from acer.com. (It's Downloading But Size shown 48.00kb only). After that i was trying for Extract it is not run. So Please help in this regards. My Laptop Model...
try to download it from any other computer
following is the link try to do it again or try any other computer to download it...
its size is around 70 mb
http://support.acer-euro.com/drivers/notebook/tm_3260.html
regards,
Dec 04, 2008 | Acer TravelMate 3260-4874 Notebook
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
