Question about Sony Playstation 3 (PS3) Console
Dik will not spin and looks like the laser will not read
    Guru:
  • 111 Answers
Basically if the laser is bad, the disc won't even "try" to spin.
It needs a new laser because the old one is "burnt out". It's a really common problem with them.
I buy mine at http://parts.consolerepairguy.com they run about $75 each.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
Posted on Jan 27, 2010
The disc will not spin. when i turn on the playstation 2, the disc starts to spin but then stops.
the laser is trying to read the disc but cant there are two main reasons for this 1 the disc is damaged 2 the laser needs cleaning go to a electronics shop and buy a laser disc cleaner
they look like this
sonicboomele_14.jpgbest of luck please rank this advice if it helped
Feb 13, 2011 | Sony PlayStation 2 Slimline Console
I cant find a dik-dik.. and what do they look like
a dik dik looks like a very tiny deer....smaller than a baby deer
Jan 03, 2010 | Activision Cabela's Big Game Hunter for...
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
The disk isn't spinning. When tray closes, it tries to spin for a moment, but then it doesn'tt.
When you first put a CD/DVD into the Playstation 2, the disc spins enough so that the laser can read if it's a CD, DVD movie, DVD ps2 game or CD ps1 or 2 game to spin at the appropriate speed. If there is no disc inside, or the laser thinks there is no disc inside, the disc will only spin that 1/2 of a turn. So what would cause the laser to think there is no disc inside?
A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable. I would suggest using a 400C since it is a better laser [and more available] than the 400B. YES, despite anything you have read, you CAN replace a 400B with a 400C IN ALL CASES.
Jun 05, 2009 | Sony PlayStation 2 (PS2) Console
KitchenAid KSM90 stand mixer transmission
Check this site there is a service manual
http://www.mendingshed.com Hope this helps.
May 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Won't work. disk won't turn
sounds like a faulty spindle. this is the part that spins your cd for the laser to read. if your using a fat ps2 its prolly the spindle. if your using a slim ps2 it could be the laser causing the problem not the spindle. the slim ps2 laser make the spindle work. if the laser isnt working right the cd might not spin or it might not spin fast enough or flat enough.
look
Mar 06, 2008 | Microsoft Xbox 360 Console
My disk wont spin at all.
it could be that your PS2's laser is fried. the laser is what reads the disk, and it could be fried because it reads so many scratched disks that the laser "burns itself out" so to speak. try looking into a repair for it.
Jan 10, 2008 | Sony PlayStation 2 Slimline Console
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
PS3 wont read any discs
Hi, Chr1s
The Laser tries hard to focus and read discs until it locks onto the data..  If it is having trouble reading a disc due to a dirty lens or hair trapped in the disc drive spindle, it will keep looking until you turn it off.  The problem with this is that the lens holding assembly is made of Linear low Density polymer Plastic.  The heat from the laser focusing over an hour like you said, has probably melted your Blue ray laser. Chances are it can be fixed, but Chances are not without buying a new laser. Hopefully you will contact Sony Support at 1800 345 7669 and attempt to get them to repair it for you. Try hard, they may come through for you. They have in the past.  SOny has a great Service department, and blows Microsoft out of the water. i  got my PSP back in 10 days.  Cost me only $5.25 to mail it to them. My PSP is fully functioanl again.
Pleas Click on Solved here, you only have one vote shot.  I have put a lot of effort into telling you what is happening for Free tip.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
