Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Thinking about installing basement Saniflo toilet
Thinking about installing basement Saniflo toilet unit , with shower and vanity basin empting into disposal unit. Questions: How noisy? Where best to situate unit? How how best to insulate? Which unit to purchase?
Ed
  • 119 Answers
Zoeller makes the best unit out there do you research first
Posted on Nov 15, 2009
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflow plus works allright for w.c but will not work for shower
Thanks for the clarification - This rules out power supply to the unit, motors/pump and points more towards why the water would be pumped from the WC flush and not the basins ...
1. The Saniflo range of macerators have a pressure switch that engages when the water pressure inside the unit activates a microswitch that is encased in a waterproof container. It is possible that the water pressure from the shower and basins is not great enough to activate the internal switch.
So, I would propose two checks
a) If the unit previously worked for the shower and basins something has changed and it is most likely to be gunk inside the unit causing the switch to be less sensitive and only activate on the high pressure that the WC would provide. The fix would be to open up the unit and clean it - please let me know if you need info on how to do this
b) If this is a new install and the shower and basins never worked, you should check the fall in the pipework into the Saniflo is sufficient (should be 1 in 70 from memory - full install instructions are available from the Saniflo website)
c) It could be that if the unit has been in for a long time with a large number of operations that the microswitch is starting to fail and is not as sensitive as it once was (quite unlikely) - but always a possibility!
Replacement microswitches are freely available online and you should also be able to get the exact match spares from Saniflo
If this helps please leave feedback - if not please let me know and I'll try and help some more!
Good Luck :)
Feb 05, 2010 | Saniflo Sanibest Grinder Pump Only 013
Size of inlet for shower for a saniplus toilet system?
The inlet pipeworks for a shower to Saniflo would normally be 2" / 52mm polypipe as per the diagram (different saniflo unit type, but they are all the same)
If this helps please leave feedback, if not - let me know and I'll try and help some more!
Jan 25, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
It starts up before I flush!
is your saniplus connected to a shower or hand basin. if so - some water could be getting into the saniplus while you are on it and causing the unit to operate while you are "on the bowl". dripping taps / valves or a "leaky" toilet cistern are the most likely sources.
Dec 04, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
The water from the loo and shower is rising & not going down
The outlet is blocked , get an engineer in to fix it pronto
Aug 24, 2009 | Saniflo Home
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
526 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
