Question about D-Link DI 514 Wireless Router (DI-514)
Routing configuration Hi, I tried to connect two different networks having different subnet masks using D-Link 514 router.But I could able to ping from one netork(LAN) to other(WAN0, and could not able to ping from WAN to LAN. The IP settings I used for the networks are as follows: ip : sub: --------- Ist network ip : sub: ---------- 2nd network. Kindly help me how to configure it correctly so that I can able to ping from both ends.
  • 45 Answers
Contact an ISP for an IP address.
configure the computers in the 2 networks to have the IP address you got from your ISP as the default gateway..
Posted on Jan 09, 2008
Static route for two different subnets
You did not say where are your two computers. Anyway, computers should work on most subnets routes except between and subnet.
Static routing should be set on two computers not on routers.
Assume computer A is connected to Router A and Computer B is connected to router B.
On Computer A, you need to add route to -inet via GW, and on computer B to set rotue to -inet 10.20.30/24via GW That is all you need.
Apr 04, 2014 | D-Link Computers & Internet
Your question is hard to follow. "got an X as it failed" what is it ?
What are the lease ip addresses from the DHCP server and what is the subnet mask ?
What is the default gateway in the DHCP lease ?
What is the router's internal IP address and subnet mask ?
What is the ip address and subnet mask of the computers used ?
What is the operating system used on computers
can you ping the router from computers ?
can you tracert
from the dos prompt for ping (routers ip address)
what route does tracert reveal
does it get to the router
does it find the dns server ?
Nov 12, 2017 | Computers & Internet
Gateway not pinging from dwl 3200 ap . AP= in the same subnet, gateway= , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress of the router then its subnet mask commonly, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Asus wl-500w and modem
your sub net mask is wrong you have to put and make to modem and to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Two way routing.
You will always have a problem because the subnet is different. Your solution lies at the Server Level if you have two different servers one must become the 2BDC, other wise you will need more hardware to setup a bridge contact D-Link as to the equipment you will need.
Coach "J"
Have a great 2008!
Jan 08, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Dec 12, 2007 | 2wire HomePortal® 1800HW Router...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? IP Subnet Mask ? Gateway ? Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to, Subnet Mask ?, Gateway - You can now try configuring the router through its web interface ( This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
D-Link DI 514 Wireless Router (DI-514) Logo
120 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
