Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
I have a Sony handycam DCR HC42. The cassette for the tape will open and close w/o a tape, but once tape is inserted, the case will not close.
  • 4 more comments
  • debcougar Nov 16, 2009
    The casseette will close about a quater of an inch, then stop. I can hear it trying but seems to be stuck.
    The tape does not spin
    My handycam will open and close w/o a cassette. When a cassette is inserted it closes about a 1/4 of in inch and stops, though you can hear it trying to close.
    The lcd screen was showing reinsert tape. I tried the whack it on the side as was posted, now it takes the tape just fine! However, when I play a tape on normal speed there are tiny boxes that go off and on on screen and audio goes in and out. On slow play, no problems. only on regular speed.
    I tried whacking the side of the hancycam as seen on some posts. Now it goes in and our just fine. When playing a tape and looking at the screen, the audio goes in and our and tiny boxes jump around on the screen. This does not happen on slow motion play
    no, i used the whack method I saw posted on the side by another user
  • 566 Answers
I`ve repaired many of those camera and the problem is almost always the capstan motor that does`nt turn . You see when the camera detects a tape it will try to rewind and forward the tape a couple of turns to take up any slack or to see if the cassette is not defective(jammed), then it will load the tape, but if the capstan motor is not able to turn that tape then it won`t. There could be a number of reason the motor can`t turn the reels,the motor or the circuit that drives the motor could be faulty or you may want to look inside the camera for debris i.e;stickers for identifying tapes that fell into the mechanics and blocks the reels.
Hope this will help. good luck
Posted on Nov 16, 2009
  • 10,594 Answers
Please check video head (drum assembly) does it spin when you close tape door with tape inside?
If video head does not spin, camcorder will not load tape, though mechanism will be loaded with out tape inside.
Post back your comments/ findings to provide you further info.
Thanks.
Posted on Nov 15, 2009
  • Shahid Electronics
    Shahid Electronics Nov 16, 2009
    Does camcorder show any error sign in its LCD while rejecting tape loading?
    it might be blinking error code like C:31:00 or some thing similar? or Dew sensor sign, a drop in yellow color?
    Post as comments to find out problem reason.
    Thanks.
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Nov 30, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
Aug 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Casette insertion device will not close or open
Hi guys,
Just try removing or adjusting Handycam's battery. It should work.
It worked for me.
Dhiraj
Nov 04, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
155 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
