Question about Motorola Mobility V360 Cellular Phone
Lost numbers after copy from phonebook to sim card - how to correct
Cannot seem to store phone numbers on the phone (Hundai HDT-L12). Have lost the manual, but looks as if it should be simple. However, I just can store 1 number only.
might be ur phonebook memory is full thats why it is not storing the nos or u have changed setting of phonebook to save a contact in sim card & u have to search no. seperately in sim card
If this solution is not satisfactory then write to me again with a full clarification
Jul 04, 2010 | Lands Phones
How do i save all my numbers to the SIM on a Sony Ericcson k800i? I'm trying to put the sim into another Sony Ericcson but recently added numbers aren't there!
Menu-Phonebook-Options-More-Advanced. Choose Copy contact from phone to SIM. The SIM card has only 250 spaces for contacts and 30 for SMS.
Oct 08, 2009 | Sony Ericsson K800i Cellular Phone
Trouble with contacts
Was your Sim card copied to the address book?
You may have to fix the entries copied from the sim card into the address book so that the cell phone number is in the correct field as well as the names. By default it may not be properly stored into the correct fields.
Mar 18, 2009 | RIM BlackBerry 8700c Cellular Phone
I need to copy phone numbers from LG CU515 phone to sim card
its easy my dear,, just go to phonebook then go to settings then select copy,, and choose from phone to sim
Mar 04, 2009 | AT&T Cell Phones
Cant copy phonebook contacts from sim card to phone memory?
Go this way
Menu > Phonebook > Options
Scroll down to Move and select.
Select Multiple from the pop out.
In the list just check All or whatever contacts you want.
HTH
Jan 07, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Can't enter anything in my phonebook on Razr v3i
I would suggest doing a master reset to the phone and then trying to copy the sim numbers to the phone. Good luck.
Dec 06, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Copying contacts to SIM card
To copy numbers from the phone to the SIM.
Select 'Menu'
Select 'Phonebook'
Select 'Contacts list'
Highlight the contact you wish to copy onto the SIM
Select 'Options'
Select 'View'
Highlight the number (not name)
Select 'Options'
Select 'Copy'
Select 'SIM'
Select 'Save' display_flip('id3944', 'divId3944');
Nov 10, 2007 | Samsung SGH-D600 Cellular Phone
Copy contacts to sim
after pressing menu wen inside of phonebook, press down 8 times then select, down once, then select and select again and giv it some time to finish the job
Nov 05, 2007 | Motorola Mobility RAZR V3
Transferring phonebook from phone to sim card
The razr that i had could only store 4 numbers on the sim card, your phone book is stored on your phone's memory not your sim. I'm pretty sure that you cannot transfer your phone book over to your sim card.
Apr 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V360 Cellular Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
