Question about Ovens
I have just moved into a new house with a very old de dietrich built in oven. The model number is 825. The top oven is a "hot air" fan oven, but the fan is only working intermittently and when it does work it isn't turning very quickly. Can someone tell me what could be the problem. Thanks
    Scholar:
  • 62 Answers
Without knowing the make cant tell for sure but it seems like your fan motor is failing and eventually will stop all together.
Posted on Nov 15, 2009
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Tip
Help! my Pyroclean De Dietrich oven is about 8 years old and the fan option has...
Before you choose to run you oven in the “Self Clean” mode be sure to read this.
After viewing many hundreds of range and oven problems there is one constant theme that comes through. “After running the self clean feature” on my oven I have this problem or that problem. Whether the oven is gas or electric does not seem to matter. The common thing is that the self cleaning feature was just used on the oven, and now it is not working, the glass broke, or you now, cannot even get the door open.
The basic idea of a self cleaning oven is to get the oven so hot that you incinerate everything that is in the oven. The heat from this process will burn up everything in the oven and sometimes things outside also. Even though the wiring and controls are built to withstand high heat, taking the oven to such high temperatures pushes everything to the limit. If something is not insulated perfectly or has shifted a bit then the heat causes it to fail. Repeated heating also wears the insulation out and causes it to break down. For this reason the self cleaning features should be used sparingly.
Manufacturers want to please the customer so even though they know that this can create problems they also know that this feature sells more products. It is in your best interest to not even use this feature if possible.
If you have a oven that will not unlock after the cycle you have a few things you can try.
First make sure that you wait long enough before you try to open the oven. If it has not cooled completely it will not open. Do not run a clean cycle when you do not have the time to let it cool completely before you need it. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and it will open. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Oct 02, 2010 | Ovens
Hot air blowing out at the top of De Dietrich oven, just after putting on new oven seal, fan seems ok what could it be.
Pending on the location of the oven (i.e. not where the seal is) it could be natural ventilation of the oven. Many ovens have ventilation underneath the stovetop.
Sep 02, 2015 | De Dietrich Ovens
How do I find the instructions manual for De Dietrich DOP705X Multifunction Plus Electric Built In Single Oven (DOP705X)
Go here: http://www.dedietrich.sg/sg/collections/oven.html#/others/user-manuals-10/ then look under User Manuals. Put in Model Number Collection - Cooking Range (or Product Number, if known), Available Language (EN), then download Manual in PDF
Dec 26, 2014 | De Dietrich Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Hi there, have just moved and my house has a de dietrich oven, model says - tem7rue henri becquer??? we do not know how to operate it properly and wondered if you can help?? regards trudie
These appliances are apparently made by a company based in the United Arab Emirates (Dubai), and
the model number info you've given is actually part of an address in French ("7 Rue" = 7th street).
The URL below shows their supported model numbers and "features", which tell you how to use their
ovens - they currently list 11 models - you'll recognize yours by the 11 photos on their web site.
http://www.dedietrichappliances.ae/dubai/others/legal-information.html#/collections/oven/
Aug 15, 2011 | De Dietrich Ovens
N Serie: 04-09-01097 Ref DOD 348XXG11 Type E248H1 52106 The above are the details of my De Dietrich oven. My fan has stopped working and I need a new seal for the main oven door and for the...
We don't offer service engineers. Look in yellow pages or ask your oven supplier for a contact. Most Domestic Appliance companies can help you.
Sep 25, 2017 | De Dietrich Ovens
My de dietrich oven is not heating. the light and fan are ok
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 28, 2011 | De Dietrich Ovens
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
