Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
It dosn't work. It was hot few day's ago. It is only one and half year' old. It dosn't show any letter on the LCD board.
27 inch lcd sylvania has no picture'only volume
Posted on Nov 15, 2009
Memorex LCD 32": after about a year a black rectangle about 24" long by 1 1/2" tall has white numbers and letters show up for several minutes goes away. Then a few days ago a large black area of about...
check the settings and see if he has any CC1 or CC's activated or any type of Closed Caption. The only time something like this happens is usually when you have it set for CC2 or something along those lines.
Nov 03, 2013 | Memorex MLT3221 32 in. LCD TV
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
I bought a SyncMaster 2333 monitor 1 and half year ago. Suddenly, my monitor does not show anything. Turn on/off switch is not working. Sometimes it shows just bluescreen. I am wondering what is wrong and...
This problem usually indicates a failure of the power supply board that runs the video control board. You can fix it but if your unit is only 1.5 years old then its still under warranty, 3 years parts and labor. Go to www.samsung.com and go to the service section to start a warranty claim. It takes about 2 weeks to go out and back to you.
BuddyMc
Feb 27, 2011 | Samsung SyncMaster 2333SW 23" LCD Monitor
Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Dec 10, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
LCD Problem: When i open up the laptop, all it shows is horizontal white and color lines/patches, which covers almost the bottom half part of the screen. The laptop is around 2 years old and this problem...
Sounds like the LCD is failing/failed. Hook up a desktop monitor and see if you have the same problem.
Replacing LCDs is not trivial. Here is a site that sells them. http://www.lcds4less.com/
Google LCD replacement and you'll find many sites.
Sep 03, 2010 | Compaq Presario C700T Notebook
''Disc Err'' no matter the disc I put
I doubt its a chip becuase if it was that hot chaip it would not be hot! For sure!
But what might be the issue is a bad hat, or laser foacus or even the laser itself. Its hard to tell I am not there but DVD players are a dime a dozen I am willing to bet if its 3 to 4 years old it might have past its prime. Even cheap branded players do not last 1 year so keep that in mind. fixing this will set you back in the financial of it. I would search other alternitives if this is a bad laser.
Thanks and please do leave postive feedback for those expert that are involved with your case today.
Jun 14, 2010 | Televison & Video
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
LCD NOT WORKING
Your batteries need to be replaced. Need new batteries.
Oct 24, 2008 | Canon PowerShot A85 Digital Camera
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
Heating & Cooling Logo
49 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
