Question about Mackie SRM-450 System
One of my mackie speakers is not producing the same volume as the other 1 ive swithced leads and output channels and even used the crossover from the good speaker to the bad speaker but there is no change ?
  • 460 Answers
Bhe 1 that does not sound right is blown..... time to buy new speakers...
Posted on Nov 15, 2009
  • novoros1 Jan 22, 2011
    Hi, the resistor r2 100 ohm is blown. The resistor located on the board with two XLR's very simple fix. Try it and it will work again like before.
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Sep 23, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
The top part of the mackie speaker isnt working. all that is working is the big bottom part, and the sound sounds like the bass is the only thing coming out.
The typical cause of this is a blown tweeter or the tweeter has broken off of the horn and fallen inside the cabinet. Remove the screws from the horn and carefully remove the assembly. Try the speaker at low volumes to see if you hear any sound at all. Next, remove one of the wires and using a 9Volt battery quickly touch the 2 leads on the tweeter. If you don't hear a click, the tweeter needs to be replaced. Contact Mackie service for a replacement.
If you hear a click, then the problem is in the crossover or amp and further investigation willbe required.
Dan
Jun 05, 2011 | Mackie SRM-450 System
I use a Mackie 1604vlz board. I have Passive EV Speakers that I use a QSC power amp for. I want to add one Powered Subwoofer to this. How can I hook up without buying a crossover? Can I run out frome the...
You can, but I would not suggest it. Depending upon the input design of the powered sub, the highs might not get filtered out. Many subs assume that they are only receiving the lows. You are better off using a crossover between the mixer and the amp for highs and the powered sub for the lows. Please note that the crossover will give you much more control over the sound quality.
Dan
Mar 29, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
The problem began with no signal output from Channel 1. Selecting the bypass for Channel 1 results in a signal being output. After complete disconnection & reconnection for bench test, the output for...
change your connection cables with new cables. and bring a good contact cleaner from radio shack near you and apply the spray over all your controls while you are moving them up and down.
Oct 11, 2009 | Rane GE-60 Home Equalizer
Mackie SRM-450 System Logo
452 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
