Question about Reebok Fit Watch 10M Strapless Heart Rate Monitor
I had a battery shop replace the battery and have reset the time, date, etc., but it is not picking up the pulse but returns to the time screen. I cannot get to the functions to set age, maximum pulse, etc. The instruction booklet is not helpful. It had always picked up my pulse without a problem until the battery was replaced.
    New Friend:
This is what worked for me.
Press & Hold MODE till it FLASHES (Seconds will flash first), then
Press ST/STP and it will jump to MINUTES, then
Press the LAP/RESET till desired Minutes. Once you do,
Press ST/STP and it will jump to HOURS, then
Press the LAP/RESET till desired HOUR (if you go past 12 it will then show p.m. and vice versa for a.m). Once the Hour is chosen,
Press MODE.
DONE!
Posted on Apr 11, 2013
After replacing the battery how do I reset the date and time
Double Click on the time, normall down left corner and tiie/date properties will apprear.
But firt check tab timezone, if ocrresponds to your zone, then return to date and time and adjut do current
May 16, 2015 | Dell Computers & Internet
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
My sl 3.0 no longer picks up the signal from sensor so speed/ride time no longer work. I have changed all batteries and checked sensor area for mud/debris etc. the unit is less than twelve months old. The...
Its probably because the computer has lost the ID nuber. It happens every time when U change the batteries or re-setup the wheel size.
It happend with me and it took a long time to figure it out.
So try theese steps out:
1: check the ID number: (hold the right (mode) button for 5 seconds till "ID" is written on the screen) - if there is no number shown thats a good sign.
2. press the reset button on the remote (before make sure that the magnet is placed close enough and it is passes right true in the center of the battery cap of the remot) so RIGHT MAGNET POSITIONING IS ESENTIAL
3. after pressing RESET spin the wheel aproximatly for one minute.
If that is the problem it should pick up the sign.
Ps. A stronger magnet might also help.
Good luck.
Oct 12, 2013 | Blackburn Atom Sl 3.0
Without using a dongle, wut els can I do without hiring anyybody. Is ther a step to step process I can do?
I assume this is a followup to resetting a toshiba laptop password.
Next time it's helpful to reply to the original message rather than posting a new one, because nobody else would know what you meant here.
Many shops will do the reset for little or no cost.
The only other thing to try is unplug it, take out the main battery, then locate and disconnect the CMOS battery. Wait about 20 minutes, then reconnect the CMOS battery, put the main battery back in and plug it back in.
You'll have to reset the time/date/ etc etc etc.
Feb 25, 2011 | Computers & Internet
IBM THINKPAD 600 - How to fix error codes 161 and 163
START WITH THE MACHINE OFF
HOLD and CONTINUE TO HOLD "F1"
WHILE STILL HOLDING "F1" TURN ON THE MACHINE
AND
This will go into bios, you'll get a green and white screen.
Set time and date there, save and exit.
Should work.
Mar 17, 2009 | IBM ThinkPad 600 Notebook
Kodac M8931S how to change date&time after first setting?
should be in setup screen. If the date does not hold after a battery change/charge, then your capacitor on the mainboard is bad, it wont affect anything but the date/time and any custom settings you have set. It can be replaced be a camera shop, but it will exceed the cost of the camera in most instances.
Dec 01, 2008 | Kodak EasyShare One Digital Camera
New ds lite will not save initial settings
Either the battery has stopped functioning properly and needs replacing, or one of the battery terminal connecters has become loose and needs to be replaced with a new battery terminal (as the battery acts as a lithium battery found in a pc to save the bios settings), but they are quite difficult to desolder and reapply, best bet is to probably get another mobo. Touch screen ribbon cable could have worked loose and needs tweaking or the connector is faulty and again needs to be replaced.
Sep 29, 2008 | Nintendo DS Lite Console
Evesham quest a240 looses the clock settings when switched off
Needs a new bios battery. Mine lasted 6 months before giving up. However you can leave the laptop plugged into the mains power when computer is switched off and the date/time will be kept. Otherwise change the bios battery or reset the time each time you use it. I phone Evesham and they said that the bios battery is soldered to the chassis on this model and so would need to be returned to the factory for this to be replaced. Since Evesham are now defunct you would need to get a PC repair shop to replace the battery. Is easy to do.
May 19, 2008 | Evesham Computers & Internet
Date and time etc
The CR2025 Lithium battery, holds the date and time in it's memory and is neccassary for the remote control to work. The CR2025 Type Lithium battery needs replacing. That should sort it. Please rate this solution
Nov 20, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Reebok Fit Watch 10M Strapless Heart Rate Monitor Logo
221 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
