Question about McCulloch Garden
Mcculloch 3516 chain saw, does not always start.
I have a mcculloch 3516 chain saw, when it runs it runs great but sometimes it won't start. I think it is an electrical issue. I changed the spark plug - no improvement. What could be wrong?
    President:
  • 2,220 Answers
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Posted on Nov 15, 2009
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Bar chain oil in my mac 3516 chain saw leaking
Yeah, you'll need to get that fixed. I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 18, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have a mac 3516 35cc the carberator is way out of adjustment where do i set idle and gas adjustment screws at
I have always found that a good place to start was to close both completly shut then open 1 1/2 turns. On idle adjust to where it will idle good and chain is not moving. At run speed adjust slowly to where it runs the smoothest at max R.P.M.s. Hope this helps.Thank you.
Dec 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to view gas line hook up. On mac3515 chainsaw
No 3515(35cc,15"bar)s a 3516 is provided.
A McCulloch Mac 3516 model model 21-600035-59. (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600035-59-Mac-3516-IPL-211318-01/139.21-600035-59-Mac-3516-IPL-211318-01.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If the above is not your saw, yours can be located here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
A typical fuel system and a couple of tips follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If properly plumbed your saw will run with the carburetor to primer hose capped off.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 14, 2010 | McCulloch 10" Electric Pole / Chain Saw
I have a MAC 3516 and need a replacement bar and chain. The original Chain and bar are not available. the saw runs good but need the primer bulb and chain bar and chain. Any ideas would be great.
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | McCulloch Garden
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Garden Logo
1,132 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
