Question about Logitech Harmony 880 LCD Remote Control
Hello, my remote ios not working for my tv anymore what should I do?
Learn the commands from the original remote in RAW mode. See the following link:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Hope that helps. If it doesnt fix the problem, then its most likely a hardware issue with the remote.
Posted on Mar 09, 2010
Hello, The DVD button is not working anymore and
The remote has its own issues.
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Hardware buttons on devices also fail. There's no magic fix for them. Do other modes select ok?
Jul 19, 2011 | Samsung HT-TXQ120 Home Theater System...
Tv code
You can refer to this website and get all the details of comcast
http://www.xdiv.com/remotes/
Jun 11, 2008 | Soyo DYLT032D 32 in. LCD Television
What kind of device can be used to inprove my tv #2 remote.got a new tv (hd tv) noe tv #2 remote wont work threw wall & doors real good anymore.what kind of device can i use?dish book said something...
Hello! Dan Busa here with Dish Network customer support. There isn't much in the way of any additional devices you can purchase. The best thing to do is to check the silver remote antennae on the receiver, if it's standing straight up you probably need to reprogram the remote. Try this link: http://www.dishnetwork.com/SupportSection/remote-setup
Dec 30, 2010 | DISH Network 322 DTV Receiver
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
Got a new tv with hd box. my mom did something and the remote dosent control the hd box anymore. it is an lg 47" LED. how do i get the hd box working again
Hello, this is fairly simple to fix. Just follow these simple steps, and that will be working for you real quick!!!!!!!!!!
Hope this helps!!!
Becki Barned
DISH Network Customer Service
Nov 21, 2010 | Universal Remote Control Dish Network...
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
Where do i find the codes to program my remote to the cable box
you can do a auto progrom
first you turn tv on
on the cable remote you have the io button and the tv button you press them both down at the same time for 3 secounds the io button will light up while it is lite you press the channel button up or down till the tv turns off then you press tv again it should blink twice to confirm the code then you will be able to use the remote with your tv if it dosent work take your time when it goes off dont hit the channel button to fast or again or you will load the next code if it dosent work try it again slowly till the tv turns off
Dec 14, 2008 | Polaroid PLA-4250A 42 in. HDTV-Ready...
I need to program my dish network remote to my Polaroid 4011-TLXB is there a code?
you can auto search with your cable remote
turn on your tv point the remote at it
press io and tv at the same time hold down for about 3 secounds the io button will flash or turn on then while io button is on you hit the channel button up or down till the tv turns off. when you hit the tv button again it will blink twice meaning the code is store, then hit the tv button it should turn on, if it misses the code try again it should work remeber to go slow till the tv goes off..
hope this helps..
Dec 13, 2008 | Televison & Video
Code for cablevision remote control
Hello Monica24g. I also have Cablevision and found the codes I was looking for. I assume you have an Audiovox (fpe1907) television. Here are some codes you can try: 076 103 043 035 224 228 078. Press the "TV" button and the "SELECT" simultaneously for 3 seconds. The IO button will light up. Enter one of the codes, then press the "TV" button again. I hope this helps!
Dec 05, 2008 | Vizio L32 32 in. LCD HDTV
Nov 20, 2008 | Audiovox FPE1907 19 in. LCD Television
Open Questions:
Logitech Harmony 880 LCD Remote Control Logo
52 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
