Question about Philips Magnavox DVD/VCR Dual Player
Philips portable dvd player need wiring diagram
jaffa012001
  • 376 Answers
SOURCE: Unlock DVD Portable Philips PET 716
1. Turn on player.
2. Open disc tray.
3. Press setup button on remote.
4. Press right button three times to highlight "preference page"
5. Type 9 6 5 3
6. Press up or down button to change the region code ("0" for all regions)
7. Press setup again to exit
Posted on Sep 08, 2008
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
SOURCE: my philips dcp850 portable dvd play battery won't
have you had this problem fixed?
Posted on Aug 09, 2010
My philips portable dvd player says "wrong disc" when trying to play a dvd. whats wrong?
The lens isnt reading the disc get a lense cleaner n run it twice that should solve the problem
Apr 07, 2013 | Philips DCP851 Portable DVD Player
Second screen not working for dual dvd player
see the diagram and test it:
some block inside can be defective, however tight any wires connectors inside, you must open the DVD.
if you can not do it go to the repair shopt TV for fix it
God bless you
Jul 20, 2012 | Philips Televison & Video
My Phillips DVD player has a white screen. It will play the DVD but still show white screen.
The wire could be loose that connects the screen to the dvd player board, these are a common problem on alot of portable dvd players.
jon
Aug 10, 2009 | Philips PET702 Portable DVD Player
Philips PET730/05
Setup
Down arrow
Down arrow
Right arrow
Left arrow
Down arrow
Enter 0
Setup to save
Jan 09, 2009 | Philips PET724 Portable DVD Player
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Jun 07, 2008 | Philips PET702 Portable DVD Player
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
Philips Magnavox DVD/VCR Dual Player Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
