Question about Apple iPod nano
Retoration went wrong
Ipod screen says "Use Itunes to restore" in enlish and several other languages. when I go to Itunes to restore it tells me that there was an error in the restoration process... Can anyone help me?
  • Cary Farah
    Cary Farah May 11, 2010
    does it give you an error number?
    Problem Solver:
  • 14 Answers
Yes for mat your ipod first then conect to itunes this will restore your setting drive g is what your looking for click then format
Posted on Jan 27, 2008
6ya staff
SOURCE:
My ipod is fully formated it is no working now what to do?
Hi, did you format properly?
If not follow this step below
What we are going to do is ERASE your iPod and then re-install the iPod's software. If your iPod has a software problem, this will probably fix it:
WARNING: YOU WILL LOSE ALL MUSIC, CONTACTS AND EVENTS ON YOUR iPOD. IF POSSIBLE, YOU MAY WANT TO BACKUP THESE FILES.
1. To erase your iPod, do the following:
ERASE YOUR iPOD (MAC OSX)
* If you have OSX, you can use Disk Utility (Macintosh HD > Applications > Utilities). If you have a PC running Microsoft Windows, click here for more instructions or read the next paragraph.
* Select your iPod in the Disk Utility window and press the Repair button
* Then press the Erase button to erase the iPod's hard drive. Extended Journaled should answer your next question.
ERASE YOUR iPOD (WINDOWS XP)
* Open "My Computer" on your Desktop
* Select "IPOD". It should be listed next to your C drive.
* Right click and chose "Format"
* Select "FAT 32" and
* Reboot Computer
ERASE YOUR iPOD (WINDOWS VISTA)
If these Vista instructions are wrong, please let us know. Vista was such a piece of **** we banned it from the office.
* Open "My computer" on your Desktop
* Right-click on iPod
* Click "Format"
* Select "Restore Device Defaults"
* Press "Start"
2. After you erase your iPod, you need to run the Restore function before your iPod will work properly. To Restore your iPod, do the following:
* Connect the iPod to your computer using the FireWire/USB cable that came with it.
* Open iTunes. Make sure you are using the newest version of iTunes. You can download iTunes updates from http://www.itunes.com
* iTunes may sense that the iPod is connected and prompt you to install any necessary software. If not, select your iPod from the Source column on the left side of your iTunes window. There will be several tabs along the top of the screen such as: Summary, Music, Photo, Contacts, etc. You should select the Summary tab.
* Click Restore.
* You may need to type in an Admin user's name and password. An alert box will ask you to confirm the restore process. Say yes.
* When the factory settings have been restored, unplug the FireWire/USB cable from iPod.
* When prompted by the iPod, reconnect the FireWire/USB cable. After the iPod has updated itself and restarted, you should see the message "Do not disconnect" flashing on the screen.
* You may be prompted by iTunes to type in a name for your iPod. Feel free to get creative.
* The "Automatically update my iPod" option is selected by default. Deselect this option if you wish and click Done. The iTunes main window appears, and the download status is displayed in the iTunes display.
* Wait until the iTunes display says the update is complete.
* Quit iTunes.
* Disconnect the FireWire/USB cable from iPod. After a few moments, the Language display appears on the iPod screen.
* Select a language. If you screw up this step click here. One time I accidentally selected Chinese for the language. That sucked.
If the iPod does not turn on at all, disconnect it from power and let it sit unconnected for approximately 24 hours. Then repeat this procedure.
If your iPod is still unresponsive, throw it away. Just kidding. If it is still under warranty, go to the AppleCare iPod Support Page to arrange for service http://depot.info.apple.com/iPod/. If your iPod is out of warranty, then use our VIP Repair Service to get it fixed.
After this process and still does not work, that means you will need to get a new ipod..
Have a nice day.
Feb 23, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod does not restore
try this: when it says error after trying the restore,press ctrl+alt+delete and select itunes and then end task....restart itunes and try the restore again....works quite often...
Sep 01, 2009 | Audio Players & Recorders
My iPod won't let me enter passcode, stuck on connnect to itunes
just connect it and go to my ipod. go there and click on restore. clickl on that and say yes. it will take around 20 mins to restore. hope this helped.
Jul 08, 2009 | Apple iPod touch
I cAN SCROOL DOWN BUT IS STUCK ON THE LANUAGE SCREEN
If your iPod is simply stuck on the wrong language, then the best way of resolving your issue will be to restore the iPod using iTunes. If it is in the correct language but stuck on the language screen I would reset it. I posted a step by step on both just to be sure I got you all the information you need. If this does not resolve your issue, please do let me know.
Learning how to reset or restart your iPod:
Article: HT1320 Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
How to restore iPod
(ARTICLE NUMBER HT1339) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
May 05, 2009 | Apple iPod nano 3rd Generation
Ipod wont restore.
have you tried resetteing it, by holding down the home and on/off button for abour 8 seconds? try that
Jul 25, 2008 | Apple iPod touch
When I connect the nano to the computer and itunes it syncs the music but when I disconnect it the ipod tells me to use Itunes to restore in four languages. I have already reset it, doing the menu and...
Check your manual -p. 50, I believe - there is a Recovery Tool for Apple described in those pages - go to Apple's website for the manual, if you have lost it
Jun 20, 2008 | Audio Players & Recorders
Frozen on language screen
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 16, 2008 | Apple iPod nano
Ipod 1st generation doesnt show up on itunes & wont restore
Do the 5 R's:
installed.
May 12, 2008 | Apple iPod nano
Help with reset
Restore should do it.
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 22, 2008 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Apple iPod nano Logo
47 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
