Question about LG Dare VX9700 Cell Phone
How do i sync music to my verizon vx9700 cel phoe via usb from the computer
How to sync verizons LG 840 with a mac computer to sync music photos etc.
For a MAC, I believe you need an SMB application. This is not free for mobiles, but I'm not sure on the MAC. SMB is a file sharing protocol that is standard for Windows file share and transfer. Apple has their own protocol that is exclusive Apple. The SMB interface app allows you to share files with a Win computer via local LAN. I do this with WiFi on my Android - PC. Really nice for quickly posting pics to net drive when you get home from outing. The Android mobile app on my LG Lucid that I use is Ghost Commander. It's a bit clunky, but once it's set up it's great for getting files from PC or posting pics-vids etc from smart phone. There are Apple SMB apps for iPhone, to do this, but the Android was free.so my LG won this personal use setup.
Dec 31, 2012 | LG Lucid VS840 4G Verizon
I cant transfer music or anything from my pc to my phone
Install the provided LG Dare software on your computer.
Using your USB cord, connect the phone to the computer.
Open windows Media Player.
Media Player should see your phone.
In the sync screen, drag music from your library to the sync column and then select sync.
This will copy the selected music to your phone.
Photos are easiest with a micro SD card, otherwise, you need software like BitPim.
Transfer photos to and from the micro SD card and the insert in your phone.
Aug 04, 2009 | LG Dare VX9700 Cell Phone
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this option, you must install V CAST Music with Rhapsody on your PC. 1. Open V CAST Music with Rhapsody software. Don’t have V CAST MUSIC with Rhapsody software? Download it for free at www.verizonwireless.com/music. 2. Install the device USB drivers before connecting your phone to a PC. USB Cable and Device Drivers can be purchased separately via the Music Essentials Kit compatible with this device. 3. From the main screen on your phone, the SYNC MUSIC V CAST MOBILE PHONE display appears. Your phone should display the message: Connected. Connection may take a few seconds. 4. Drag and drop the song(s) you want to sync from My Library, to your V CAST Music with Rhapsody mobile phone, listed under the Sources tab. Once synchronization is complete, press the END/Power Key and disconnect the USB cable (purchased separately). 5. Under the Music & Tones menu, open My Music to view and play your music. • A compatible USB cable (sold separately) is required for syncing. • Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 17, 2009 | UTStarcom Blitz Cell Phone
I cannot connect to my V CAST. When I plug my Dare into the Computer to Try to SYNC my music, V CAST says "Connection Failure- Please check your cable connection to the PC" It is all connected but I don't...
WITHOUT sd card
go to my music, sync
should get red screen that says connecting...
then
v cast mobile phone
internal memory
select what program you use to sync with wmp, media monkey etc.
if you cant get that far make sure you have needed drivers, if possible try with different pc and or different usb port and i did have a bad oem usb cable
Jun 07, 2009 | LG Dare VX9700 Cell Phone
LG CDMA USB modem
sync your music! you dnt need to download the drivers. the dare will automatically pik it up! also use it as a mass storage then copy and paste your music to your portable drive as it will show up in my computer. good luck sport!
Apr 24, 2009 | LG Dare VX9700 Cell Phone
Lg versa with 16gb sdhc freezes when synced with computer
u need to take it to the verizon st0re. they will reflash it for free. that means they replace the old file system with a new updated one. make sure you have backed all your music and photos. reflashing CAN delete them.
Apr 16, 2009 | LG Dare VX9700 Cell Phone
How do you get music on your verizon phone without paying monthly
Using your supplied USB cable, connect your phone (after installing the drivers) to your computer.
On your phone, goto "My Music" and click on "sync".
Option 1:
Your Windows "Portable Device" connect pop up should appear.
Double click on "Sync digital media files to this device..." OR
Jan 05, 2009 | LG Dare VX9700 Cell Phone
Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Jan 22, 2008 | Cell Phones
Problems with LG enV VX9900 music uploading
I found the solution.
First let me say that calling Verizon tech support is a frustrating process to say the least. I have spent hours on the phone with three different reps, all with different levels of knowledge on the subject. But I'm beginning to digress - Bottom line, calling Verizon tech support is hit-or-miss.
After multiple attempts of installing and uninstalling the rhapsody software, the vcast software and the phone drivers onto my laptop with and without the phone plugged in, I was still not getting my phone to connect. So after I was just about through with Verizon reps, I called Rhapsody tech support, and they insisted it was a phone issue. Having no where else to turn, I drove to the verizon store to DOWNGRADE the phone to something simpler, when their highly trained personnel actually diagnosed the problem.
Turns out the nothing was wrong with my laptop, or wire, or USB, but rather the only way to get the phone to connect was to bring it to the store and have VERIZON update the software on it. You cannot do this over the airways using 228. They must do it there. Actually, there have been four updates to this phone's software since I bought it only 4 months ago (I had version "4" and they are up to version "8"). After the software update, the phone connected and now I am able to drag and drop to the phone shown in the same pane as "my library."
Save some time - bring it to the store.
Oct 20, 2007 | LG enV VX9900 Cellular Phone
LG Dare VX9700  Cell Phone Logo
150 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
