Question about Amana ABB1927DE Bottom Freezer Refrigerator
I replaced the relay switch on my Amana fridge. I can hear it click but the compressor is not engaging. What do you think?
    President:
  • 1,218 Answers
Good day,
If you replaced the compressor start relay then if the compressor refuses to start, then it is an internal problem with the compressor.
If the start components that mount to the compressor body also include a capacitor, it could have failed as well.
If your machine does not include a capacitor, you can try what is called a 3 in 1 which is what is called a hard start kit,
But is an iffy path to follow, and may either not work at all, or for only a short time.
P.S. If the machine is under 5 years of age. Leave it alone and call your selling dealer for a warranty repair. The compressor has a 5 year warranty on it.
Posted on Nov 15, 2009
I have an Amana fridge model number abb2224dew. The compressor is very hot and the relay/capacitor is buzzing/clicking. The compressor will not startup. What is causing the compressor to heat up and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
1996 Lincoln Town Car. The A/C compressor will not engage. Freon is not an issue because I have by-passed the low pressure cycle switch. The control in the car is on "max ac". I have also replaced the A/C...
Is the solenoid clutch holding on to engage the compressor, if not the relay or the fuse or the sitch is not active. check the connection to the relay.
If solenoid is turning the compressor then there is no pumping and so the cooling does not happen.It can be failure within the compressor, needs an overhauling .
Sep 29, 2010 | Lincoln Town Car Cars & Trucks
GE TBX25ZLB Refrigerator Compressor won't Engage
Part number for compressor relay is WR7X222. However, you have a very old rotary compressor there and most likely it went bad. I would just buy a new fridge. Don't waste your time/money. The fridge is too old.
GE refrigerator repair in orange county, ca
Feb 06, 2010 | Refrigerators
Amana side by side fridge and freezer not cold.The model #ASD2624HES I have done some research and I think it might be the relay switch or the compresser.If anyone had has this problem with this model...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Part 4 on this diagram is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2624HES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATION&diagramPageId=00013&componentDescription=COMPRESSOR&documentId=M0608085&backToLink=Return%20to%20subcomponent%20list Here's how you can check it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Amana 26 cu. ft. Side-By-Side...
Amana side by side Refrigerator model #asd2624hes is not cooling
its most likley the compressor if you wire the compressor independently and get the same sound then you will have to replace it
Sep 22, 2009 | Amana ARS2661B Side by Side Refrigerator
Compressor not coming on,temp is warm in freezer/fridge
You have a defective start relay on the compressor. That is your clicking sound. The overload relay is disengaging when you hear the click.
Replace the compressor start relay.
Jul 07, 2009 | Frigidaire Refrigerators
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
769 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
