Question about Kenmore Kitchen Ranges
Oven dont work a f-1 fault number is display - Kenmore Kitchen Ranges
  • 6,784 Answers
HI. This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock). If your unit is not configured this way, follow this simple test to confirm which board is damaged.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2.
Gain access inside the control panel.
3.
Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4.
Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5.
Turn the power back on.
6.
Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7.
If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 15, 2009
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
F1 fault when oven is just sitting.
There are several sufix numbers after your model number so I just picked one, They are often the same as they usually keep the same wiring harness and circuitry through out many.Here's what I've found, Electronic control has detected a fault
condition. Press CLEAR/OFF to clear the display and stop the
beeping. Reprogram oven. If fault remains, record fault number.
Press CLEAR/OFF and contact a Service Professional. See:
https://www.searspartsdirect.com/partsdirect/user-manuals/GLEF396ABA-Frigidaire-Parts-Range-Parts-manual#
or choose from your complete model number:
https://www.searspartsdirect.com/model/search.html?q=GLEF396
Good luck
Oct 30, 2017 | Frigidaire GLEF396 Electric Kitchen Range
MODEL NUMBER HR7E SERIAL NUMBER 46-2000-893 DOUBLE DECK OVEN GIVEN A FAULT OF PHE.... WHAT DOES THIS MEAN?
ON START UP WHEN OVEN IS COLD IT WIL DISPLAY PHE TIL IT REACH A CERTIAN TEMP IF IT KEEP ON DISPLAYING PHE REPLACE YOUR TEMP PROBE
Jan 28, 2010 | Hobart HR7E Electric Single Oven
Samsung oven bf641fst displays -SE- How do you fix
According to the crappy manual:
-SE-
An error of the oven may cause low performance and problems in safety. Stop using oven immediately and call service man.
Means very little I know.
Jan 14, 2010 | Ovens
Oven does not work f3 in the screen
Oven control beeps and displays any F code
error (for example F11).
Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/
OFF and call your dealer or authorized service agent for assistance.
Dec 17, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
Oct 02, 2008 | Frigidaire Kitchen Ranges
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
What is this F-! mean
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Sep 03, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
23 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
