Question about Welding Tools
Hi i have a maypole proturbo 170 which is made by telwin not used very often stopped woring amp switch fan working but no power to wire feed motor can you help mig about 15yrs old
  • 218 Answers
SOURCE: I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Posted on Feb 23, 2009
luxur4
  • 92 Answers
SOURCE: have a 110 volt mig wire feed. motor slows to a
Hi Stan, the best thing to do is phone Hobart or the hobart agent for a price on a new motor, however this sounds like it is a power transistor over heating in the circuit, these power transistors are mounted on a large "fined" aluminum plate, take a look for signs of heat around the transistor mounting or have a decent electrician to test them, referring back to Hobart, these guy's provide good service, they have a help line also but I don't have the number.
lets know how thing work out
Posted on Mar 01, 2009
mamicheddy
  • 79 Answers
SOURCE: lincoln 175hd mig will not feed.
Make sure your roller motor is spinning. If it is, then adjust the rollers tight enough to spin out the wire. If power is available and motor does not spin, check the fuse on the control board. If it is ok, then it is your control board.
Posted on May 06, 2009
SOURCE: can you help with the settings on this mig welder
Can you explain what settings you want to know
http://www.mig-welding.co.uk would be where I'd go
Posted on May 09, 2009
  • 850 Answers
SOURCE: My welder just stopped
your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
Posted on Jul 20, 2009
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
Would like to if the telwin bimax 182 turbo have stitch timer an where do i find it on the machine?machine is to years old.
Hi there, the Bimax 182 has the stitch weld switch between the wire feed speed control and stitch weld timer, just flick it on and you are in business,
cheers.
Dec 18, 2010 | Atd Tools Welding Tools
How do the radiator fans work? straight 12 V power in ground out? What damage could be done by wiring one fan directly, with a toggle switch, and hooked to a fuse and then grounded?
it's controled by a fan switch, when it get to a certain temperature the switch closed and power the relay which makes contact to feed power to the fan.
you can do a toggle switch like that, make sure you have right size of wires and the switch can handle the load, and the fuse is the right amp.
the possible damage is that if you ever forget to turn off it will drain your battery and make the fan motor go bad quicker.
Mar 07, 2010 | 1994 Oldsmobile Cutlass Ciera
Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Feb 25, 2010 | Hobart Welding Tools
My welder just stopped welding. It's a Telwin 220 Mig. The fan is still running but there is no noise from the welder and the wire is not feeding. I had only used it for around 30 seconds before it...
Cheer Rob.
Jul 16, 2009 | Astro Pneumatic 3 Pk. MIG Welder Torch Tip...
Lights and wall switch will not work
If the wall switch will not work at all, but the fan still works this tells me the power is not being sent to the switch and back to the fan. If it is a single switch and the power starts at the fan there should be a black and white wire on the switch. (pull switch out of the wall to check...turn power off first!!) If so they did a switch loop and the power wire should be connected to the white wire up in the fan box and the power (black) wire connected to your fan lights and fan motor. You will also see your power feed cable consisting of a black and white wire. Black is your power and white is your neutral. That white wire will be connected to the neutral wires of your fan lights and motor. (Note: your fan will have to disassembled and taken down to diagnose this). Good Luck!!
Jul 15, 2008 | Minka Aire F812-IO Lineage? Fan
Welding Tools Logo
228 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
