Question about Garden
I have a 25hp sears tractor with a 46'' deck. It has sat for three years without being started. I have replaced the battery and drained the gas and replaced it with clean gas. It will crank, but no attempt to start. I sprayed started fluid in the opening of the carb, but nothing happens. It is difficult to get to a shop, but it is possible. Any suggestions before I take it in. Jim
  • 148 Answers
SOURCE: Engine stalls
DId you remove the existing gas or just topped it off? If you topped it off, I would dump the fuel and replace the fuel filter, after that I would clean the carb (Spray cleaner).
Posted on May 20, 2009
  • 11 Answers
SOURCE: Model 180 John Deere garden tractor won't start
*cyliniod sticking... try banging on it with the blunt end of a good heavy screw driver / or the handle of a hammer. might free up the contacts, or it might be too rusted inside...
*yes to the first part about starting fluid...the starting fluid should have fired off the motor for a few seconds...so since you didnt get anything after this, it sounds like your not getting adequite fire to the cylinder (s) .
i would try a new spark plug since that would be the cheapest thing to start with first.
Posted on Jun 24, 2009
  • 148 Answers
SOURCE: Kohler 22 HP Engine 2 cyl craftsman lawn tractor
Have you pulled the filter out to see if it's clogged? The easiest way is to remove from the system and blow through the filter. If you can blow through easily then you might have a bad fuel pump.
Mike
Posted on Aug 24, 2009
SOURCE: 10 year old Craftsman Lawn Tractor won't start
I had a similar problem and found that the float was hanging up on the wall of the carb fuel chamber. I sanded lightly the outer edge of the float and never had the problem again. That was 3 years ago. Having a different problem now. After setting overnight in cold weather, 20's, engine turns over very slowly even with a new battery. Engine starts, but barely. Once running, everything seems fine. After shutoff, engine restarts quickly. Next morning, same thing happens. Anyone have any thoughts?
Posted on Dec 28, 2009
  • 95 Answers
SOURCE: i have a craftsman Lt 1000, 17.5 hp tractor. It
Check for cracked fuel lines, plugged fuel filter, if all ok, then check fuel pump.
Posted on Mar 14, 2010
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Craftsman DGS6500/917.28746 - Is there a 46" AYP deck that will bolt on to this tractor? My 54" deck is cracked and the mandrels are bent so I was thinking I Gould get a better cut.
there should be contact sears online service department for deck but if it is over 5 years old your going to have trouble finding a deck sears might have one but it will maybe 400.00 to 600.00 dollars thats a complete deck with everything on it all you have to do is install it
Sep 12, 2014 | Garden
How to replace a torsion spring to a mowing deck and defector ?
Go to the Sears dot com parts site and enter you model number. They will have diagrams that will help you. Model and year would be helpful. Hope this helps please post comment if it does.
May 08, 2014 | Sears Craftsman 46 in Mulching Tractor...
Bad gas
drain tand at end of hose.remove and clean plug. crank engine so bad gas is out of cylinders.drain ard ob bommto bowl(unscrew lightly)i /2 can heet premium gas replace plug and mow
Oct 01, 2012 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
54" Cub Cadet deck leaves strip of grass since I replaced the spindal
all three blades have to be lined up the same way when you put the belt back on.
Sep 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
May 09, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Gas in the crankcase
need to do compression test to test piston rings and check carb float possible sticking allowing fuel to keep flowing
Apr 08, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
I have a craftsman Lt 1000, 17.5 hp tractor. It
Mar 14, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine stalls
May 20, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
