I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
    Sergeant:
    Champion:
  • 289 Answers
Remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Posted on Nov 15, 2009
2 Suggested Answers
SOURCE: How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Posted on Oct 13, 2009
Agator doesn't work
Is this a whirlpool washer? The agitator dogs need to be replaced. Remove top cap on agitator, then plastic cover inside it, then remove bolt, then pull agitator off. Top can separate from bottom by standing on bottom and pulling up on upper. Go to Repairclinic.com to find agitator dogs.
Nov 19, 2011 | Whirlpool Washing Machines
Tip
Whirlpool: How to replace the dog kit of direct drive washers
How to replace the dog kit in agitator
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16" bolt and lift the agitator out of the washer. Separate the upper and lower pieces of the agitator and replace the dog kit inside the upper part of the agitator. Make sure the 4 pieces remain in place while putting the agitator back together.
on Feb 12, 2010 | Washing Machines
Top part of agitator doesn't turn.
You need agitator dogs. The part number is 80040. The agitator needs to be removed and separated to replace these components. They are geared teeth that strip out over time. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing agitator dog ears
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The top part of the aggatator does not turn
Washer has trouble agitating... Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid.
Replace the dogs its a easy fix for you
Dec 28, 2009 | Whirlpool Washing Machines
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Agitator will not make contact on every turn/hit and miss
Hi, The dog kit is bad inside the agitator. Here is how to change them.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator not working
you can put a serch in you tube for" motor coupling repair" simple enough procedure, easier to watch then explain... part number 285753
Nov 10, 2008 | Whirlpool LSN1000LW Top Load Washer
No agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
957 people viewed this question
Top Washing Machines Experts
