Question about Zenith R56W36 56" Rear Projection Television
Convergence 3D
I pressed the convergence button and now everything is in 3D and not lined up properly. I would really really appresiate your help.. thank you from mike amad mikeamad@hotmail,com
  • mikeamad Feb 07, 2008
    I've tried to adust the tv about two hundred times with no luck. All it keeps doing when we press the auto convergence is to move the colors around this screen for about one minute than it go's back to the 3d picture wich pisses me off so much that I want to set this tv on fire. Please help me
  • mikeamad Feb 08, 2008
    where would the sensor be located on the tv. thank you for your help.
  • 39 Answers
You have to try auto convergance from the menu.
There ust be convergance adjustment on menu.You will find cross at center of the screen.green cross is the refrance ,you have to overlap red and blue to form white cross.
once you have formed white cross than the picture will be perfect.
Posted on Jan 09, 2008
Inner side of screen.once u open back cover u will see back side of front screen and check at edges of the screen
Posted on Feb 14, 2008
What I suspect that the convegance sensor could be covered with some dust.See what Happens when you press auto convergance the sensors at the edge of the screen detects the reflection from the mirror inside the unit and balances it well.I asume that there is no electrical problem since you said the probelm occured after you press auto convergance button.
If any of the sensor is not detecting the reflection than it will be not able to balance.ths sensors are inside the tv cabinet and fixed at the adge of the screen.If you can try cleaning it well.or get tech who can assist.
Posted on Feb 08, 2008
Black screen in 3d view
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 28, 2010 | Punch ! Professional Home Design Suite for...
Picture in 3d without the 3d glasses
your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for replacing the convergence STKics just click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further assistance.
thanks.
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv looks like it is in 3D without 3D glasses,
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture arced and looks 3D. Plus the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
My tv went multi colored take it as it looks like a 3d television
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Pic looks like 3d
Convergence chip and capacitors damaged on the Y sustain board Cant be tuned from the unit controls
Please rate my help++++Thanks for using FIXYA
Oct 24, 2009 | RCA R52WH73 Projection Television
I pressed the auto convergence button now it looks like its in 3d
  • Screen looks 3D
Oct 16, 2009 | Zenith R57W46 57" Rear Projection...
The tv is showing everything kind of double and everything is double lined in red and green
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Looks 3d
Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Dec 26, 2008 | JVC AV-65WP74 Rear Projection Television
Zenith r56w36 56 in
My picture was fine but I had just got cable and wanted to make sure the picture was right. So I hit the auto convergence and now I have a 3 D look. I have never had any problems prior to this. What can I do? and what was is the problem? Thanks
Dec 19, 2007 | Zenith R56W36 56" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
109 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
