Question about Refrigerators
I have a side by side Fridge. Model TPX24PRBBWW
I have a side by side Fridge. Model TPX24PRBBWW Ser. TT266920. My trouble is the ice dispencer is extremly slow at producing ice. It has had periods in the past where it would make tons of ice very fast and there are times like now when it takes days to fill the ice bin. The freezer seams to freeze food fast and I have the settings on #1, The Freash foods is also on #1 or it likes to freeze the mike or what ever is on the top shelf near the freezer. Please help ???? Thanks, AJ
    Problem Solver:
  • 11 Answers
Turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Posted on Nov 15, 2009
I have a side by side westinghouse fridge with water and ice dispencer. the springs that control the lever for ice dispencing are either of their hinges or fell off how do i get in there to fix it
Insert a pin in the slot under the lower edge of the trim, You should see 2 small holes, that will release the lock tabs, from there you can just pull the frame toward you, Inside you will be able to see the problem.
May 19, 2011 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
The flap for the ice dispencer on the freezer side of the door will not stay closed. There seems to be a part missing from the flap. Maybe a spring or something. Can I get this fixed myself for less than...
you need to send the model number so i can look up your machine to see the part numbers,there's a piston that is used to close the dispencer door,close it and don't use it,if alot of hot air gets sucked inside there it could cause big problems depending on how wide open it is.the model number is on the right side wall up near the ceiling in the fridge side or if it's older it could be down near the bottom hindge on the fridge door.send the model number,i don't know if that part is less than 50 bucks
Aug 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have water running to the fridge and contact at dispencer by I cannot get water to ice maker or dispencer
Look on the backside of the fridge for a small shutoff valve which may be turned off. Also, if your fridge has provisions for a filter, check for a clogged or missing filter. In either case, you will have to replace the filter.
Jun 11, 2010 | Frigidaire PLHS267ZA Side by Side...
Fridge will not make ice
This happens on my Sub Zero. I turn the whole fridge off for 30 seconds and this resets the teeny-weeny "brain" on the ice maker. Simple and can't hurt to try.....
May 01, 2010 | Kenmore Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ge fridge 1
is looks like you need to trouble shoot *********** board is this unit has one i can see if i can fix it for you bu i need more info how old is it is it side by side let me know call 562-688-3627
Sep 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
