Question about Whirlpool Calypso GVW9959K Top Load Washer
Our wash load became unbalanced. We unloaded it, but now it won't spin. Are there things we can try before calling in a repair person?
    Brigadier General:
  • 3,513 Answers
When your washing machine has trouble with its draining mechanisms that you are in for some trouble.Many times when you keep finding that the washer is not fully drained, you may find the washer becoming "unbalanced" which causes the mechanism to stop spinning out the water. This may be no more than an adjustment to the mechanisms that sense that a load is unbalanced.
Washing machine can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
The Problem
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
Leveling the Washer
Balance problems are common in machines that are not leveled properly. Place a carpenter's level across the top of the washer and if the machine is not level, adjust the machine feet. There will be one at each corner, or just two in front. You can adjust these bolts by turning them with a wrench or pliers (see Resources).
Floor Problems
Floors amplify vibrations from the washer, and any material other than concrete can be a problem. Try putting the machine on a large sheet of plywood that's at least 3/4-inch thick. This provides a heavy flat base of support for the machine, to circumvent issues with floors that are a bit uneven. If possible, fasten the plywood to the floor.
Heavy Loads
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Washing Machine Age
A washing machine tub is supported by coiled springs, pistons, or counterbalances, and this mechanism can become detached at one or more places. Also, springs and pistons eventually wear out and become unable to support the heavy weight of the water and contents in a balanced way. At this point, you may have to balance most loads of wash at some point during the spin cycle and will probably need to buy a new washing machine.
In short You can begin to balance a washing machine by checking the load of wash to see if it is causing the machine to be unbalanced. Heavy items in the washer can be one cause of this problem. Open the washing machine lid or door and redistribute the items inside. If redistributing the contents and restarting the machine does not resolve the problem, take some clothes out, as smaller loads are less likely to become unbalanced.
If a heavy load did not cause the problem, take a carpenter's level and check the washer from side to side as well as front to back. If the level indicates the machine is tilted, check to see if the washing machine feet are adjustable. If so, adjustment the feet until the machine is sitting level. If you cannot adjust the feet, try placing a piece of foam or rubber under the part of the machine that appears to have the problem.
The best surface for a washing machine, particularly a front loader, is a concrete floor. Washing machines can become very heavy weight due to the weight of the water. If the machine is not on concrete, you may want to reinforce the floor joists, if possible, which may help balance a washing machine sitting on a floor that has sagged.
The compartment inside a washing machine where the clothes are placed is called the drum. Many machines have a weight attached to this drum, designed to prevent too much vibration. Check to see if the bolts on the drum are loose, and if so, tighten them using a wrench.
If your machine is still unbalanced, it may not have been installed properly. A restraining bolt usually holds the drum in place during transport, and if this is not removed properly, it can cause problems. Check the drum for a bolt or clips and make sure nothing is blocking the drum from moving properly.
Thanks for contacting Fixya.com
Posted on Nov 15, 2009
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Samsungj1045 washes but won't spin out past 7
Try this, unload the washer and put it into spin manually. If it spins for the whole cycle then it is your motor over heating, with the load.
May 07, 2011 | Samsung Washing Machines
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
Violently spins during spin cycle (even unloaded). Amana top load model NAV2335aww.
Is it unbalanced spin and noisy? If it is, then you bearings are out. If just unbalanced check your base and washer support inside machine.
Dec 15, 2010 | Washing Machines
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Got a 4 year old zanussi washing machine and its developed a fault where when it gets to the spin part of the program it just sits there and does nothing,read the manual about unbalanced loading but even...
check wether it does the same thing unloaded if not then its likely to be carbon brushes ,,, presuming it is tumbling durin the wash/ rinse cycles also check front filter zanussi wms will not spin if they cannot clear all water in the drum
Jun 19, 2008 | Washing Machines
Spinning Problem
you probably wore out the outertub bearing.Very expensive repair.
Jun 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin, error LE appears on display
If the washer seems to complete all of its cycles, but doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
May 06, 2007 | LG WM-1832C Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
