Question about Frigidaire Dishwashers
Electrolux dishwasher won't drain
Electrolux Frigidaire dishwasher operates properly but does not fully drain out when finished. No kinks, air space not an issue.
  • Anonymous Mar 17, 2014
    electrolux icon dishwasher fills and drains
Did u fix this? having same problem
Posted on May 31, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Dishwasher isn't draining properly
check your piston and nut assembly has to have air tight seal to drain properly should be free moving if not replace it about $15 online
Dec 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
Standing water in model FDB1050RESO frigidaire electrolux dishwasher 2005 model
Good Afternoon Friend,
I see that you have standing water in your Frigidaire dishwasher, model# FDB105RES. I would suggest trying the troubleshooting tips below:
• If your appliance is hooked up to a food waste disposer, make sure the disposer is empty.
• Check to see if the knockout plug has been removed from inside the food waste disposer inlet.
• Check to see if the drain hose is kinked.
• Make sure the cycle is complete and not in a pause mode.
If you are still having trouble with your dishwasher not draining, I recommend contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux dishwasher water left in the bottom
make sure your drain hose behind the unit is not bent or kinked
Apr 12, 2010 | Dishwashers
Water will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Electrolux Frigidaire Professional Series...
Electrolux wt 30 draining problem
It sounds like either there is a kink in the drain hose, is very blocked with gunge, or the pump is not doing it's job.
Taking the pump apart may reveal damaged rotors, debris, or if ok, the run capacitor may need replacing.
Read up on AC motors and run capacitors before going looking for it.
Aug 04, 2009 | Electrolux WT30H240DU Dishwasher
Dishwashers Logo
1,155 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
