Question about SySTOR Systems (400S52) Burner
Klh cdr-1000, i just purchase this online from craigslist i bought home and hooked it up and it played a couple tracks from a cd on the cd/cdr side and i took it out and put a blank in the other side which is cdrw/mp3 and it will not return the disk and now either door will not open and i was trying to record on analog from my stereo turntable now im not new at this i know that those dooes or suppose to open no matter what and now when i turn it on it's saying system is itainionalizing or something to that affect
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
Should recorder play cds bought from shop
Yes it should play all cd's - the laser is either dirty or needs replacing assuming it can spin discs ok.
Jun 16, 2008 | Denon CDR-M30 CD Recorder
Deck A will not play/Deck B OK
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Feb 14, 2008 | KLH CDR2000 2-Disc CD Recorder
KLH CDR 2000 2-Disc CD Recorder
I have one somewhere I can scan and post. Sorry can't fax you as am in UK.
Jan 27, 2008 | KLH CDR2000 2-Disc CD Recorder
Cdr side reads software problem
Common issue with this machine. Do you have the update disc? It is available online IIRC but I do not know where. Google is your friend :-)
Jan 04, 2008 | KLH CDR2000 2-Disc CD Recorder
Computers & Internet Logo
149 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
