Question about GE Profile PFSF6PK Bottom Freezer French Door Refrigerator
I have a popping sound coming from the ice maker it goes in intervals of about 3 sec, for around 10 mins. but only occurs about every four or five hours. Can your help me? Thanks Rick
    Problem Solver:
  • 11 Answers
If it is making ice, don't worry about it!!!
Posted on Nov 15, 2009
Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Apr 29, 2016 | Freezers
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Amana fridge periodically makes a buzzing noise 4 times every 3 min for about 10-15 min then goes away for awhile then does it all over again
is your ice maker making ice sounds like water solenoid or the motor that turns the dump fingers is stuck this will happen if the heating element is not working, After ice is made the heating element comes on for a few sec.to release the ice from tray then motor comes on makes a full rotation to push ice out.
Dec 16, 2012 | Refrigerators
New (3 days old) Kenmore Elite refrigerator model 795.7103 with ice maker. Water supply line to the ice maker immediately froze up so won't fill tray to make ice. Serviceman came out and melted ice...
First of all, your freezer should be much lower than 38 degrees. For the ice maker to even work proplerly it has to be below 10 F. Some models have a heater that goes around the fill tube to keep that from happening, but in my opinion, if its only three days old, take it back because it's much too soon for that problem to be occuring.
Nov 10, 2010 | Refrigerators
A buzzing noise comes on every 2 mins for about 45 seconds
2 things, eithere the ice maker is "calling for water" and your not hiiked to a water supply. in which case simply turn of ice maker till you restore water to the machine.
ohter noise sounds if perhaps the compressor is not cycling correctly, overheating, nad when tries to restart you hear it try for 10 secs or so, then click off. in which case youll seee the freezer stating to lose "cool" especially "wet ice" and/or soft ice cream products.. if this is the case you can try to clean the coils under/behind the refrig, and may need to replace the starting device mounted to the side of the compressor
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
Noise from the lower vents
for sure check level of freon
Oct 09, 2008 | 2003 Mercedes-Benz M-Class
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Kltchen aide icemaker
check controls make sure no one has changed settiings should be around middle setting
Is your freezer keeping the right temps?? If freezer temp has changed it will affect ice production, stick themomator and check freezer temp
Look at ice maker make sure theres no blockage of pieces of ice slowing ice maker
Oct 23, 2007 | KitchenAid KSRS25IL Side by Side...
Ice Maker does not work
My ice maker jams up once in awhile. I use a hair dryer aimed at the mechanism on high. Avoid close contact air flow directly on plastic parts. Takes 2 to 3 minutes.You will hear machanism pop several times, then wire raise up and drop.
Jun 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
Noise from bottom of Frig
could be a solenoid going bad. these are usually located and the back rear of the unit, access it from behind (pull it out from the wall). take care .. it's energized with 120 volts AC. you can get a new solenoid unit at applicance parts places. OR solenoids could be okay and something (water or ice) is signalling it to actuate every 5 min.
Mar 05, 2007 | Maytag MSD2756GES Side by Side...
GE Profile PFSF6PK Bottom Freezer French Door Refrigerator Logo
187 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
