Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The remotes are no longer working... we changed
The remotes are no longer working... we changed the batteries...but still no luck.. what could be the problem??
    President:
  • 3,197 Answers
Make sure the light in the wall control is not flickering. If it is press and hold the button with the lock icon for 3 seconds and release. If this isn't the case your receiver which is part of the logic board has failed.
Posted on Nov 15, 2009
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
Remote control no longer works on quasar 3233, have replaced batteries and purchased new universal remote with no luck, have to use manual buttons
its more than likley your sensor on your teli. try your menu to see if there is a manual or a remote setting that you can change.
Oct 16, 2010 | Quasar SP-3233 TV
Remote failure
Check your metal connection that you slide your battery in between upon changing it. I had the same problem in which my car issued a warning "FOB". And what had happened was one of my connections fell off my circuit board. So if you have a steady hand and a solder gun, it may fix your problem.
Sep 10, 2009 | 474L TX 4-Button Replacement TX Remote
Ford 2000 Taurus, Keyless entry remote no longer works. Changed battery no luck. Tried reprograming and found door locks did not cycle open closed. Could not go further. Any ideas? Thanks, Al
I have a 2000 ford Taurus and my keyless remote has stopped working and having problems with key unlocking the door from outside, none of the remote work do u have any idea what my problem could be ?
Jul 30, 2009 | Ford Taurus Cars & Trucks
Remote control that no longer works, ie. no response from the TV despite changing the batteries
You can get an IR remote tester at radio chack or frys. It's just a card that you point and shoot at with the remote. If you do not see red flashing on the card replace the remote . If you do then call serv shop. remote reciever is bad.
Apr 24, 2009 | Televison & Video
Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Jul 06, 2008 | Heating & Cooling
Remote No Longer Works
It appears the remote sensor in the Television itself has stopped working. If the TV is still under warranty I would try to contact the manufacturer to see what they can do for you. Can you still change channels manually? If so, this is most likely the case.
Dec 29, 2007 | Philips Magnavox 27MS343S 27" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
57 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
